Results 1 to 9 of 9
Thread: Only one seized bolt hold seal plate
    How can I get the bugger off, I dont want to replace the motor without putting seal back on. and I just wanna be able to get this bolt out so I can have pc of mind as well
    25K
    Sand Filter
    Bleach is my source to chlorinate with
    22,553
    Re: Only one seized bolt hold seal plate
    Any info on what you're trying to take the bolt out of?
    Did you try whacking it with a hammer directly on the head?
    Did you try penetrating lube?
    Did you try heating it a bit?
    3 other bolts are missing from the seal plate on my pump, my motor stopped working last night and I have a replacement sitting here ready to go but cant get the seal plate off
    1 bolt is all holding it on
    25K
    Sand Filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    If you can post a picture we may get a better idea how to help get it off.
    Love TFP? Become a
    TFP Supporter!
    its not coming out tried, so I purchased from HD supply to get a new seal plate
    and seal 75.00 total didn't think was too bad, just hope now it was the motor not the pump that has quit working
    25K
    Sand Filter
    All that has been taken care of, another question that I now have and it might be a no brainer but I have no brain. So when I am full skimmer, which is how I think I will need to run my pool vac the pump doesn't stay primed as if it were on skimmer and bottom drain mode, is this normal, or something amiss???
    25K
    Sand Filter
    Jun 2013
    SpringHill FL
    415
    Air leak some where between your skimmer and the pump would be my guess
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    So this would be underground???
    25K
    Sand Filter
    Jun 2013
    SpringHill FL
    415
    Most of the time it is right at the pump lid or the plumbing conections just before the pump
    Nathan
