Thread: plumbing touches rebar - is this a problem?
    Jul 2013
    Saint Louis, MO
    24
    My main drain plumbing was done today. The rebar is right on top of the PVC. Is this ok? Shouldn't the pipe be further under ground so that the rebar is fully encased in concrete?
    ____________________________________________
    18x40 ft shotcrete, 4-8 ft deep. Pebble Sheen finish. Coverstar auto cover. Hayward c4030 filter. Hayward H series 300k BTU. Intelliflo pump. Intellichlor IC40. Pentair Easytouch controls. Dolphin Nautilus robot.
    May 2013
    Tulsa, OK
    83
    Re: plumbing touches rebar - is this a problem?
    You want a bare minimum of 1" of clearance around any rebar and pipe. I would want closer to 2" but wouldn't be comfortable with less then an inch. You want the aggregate to be able to travel between the pipe and the reinforcing steel.
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Jul 2013
    Saint Louis, MO
    24
    Thanks for the quick response, heavyweight. Do you think there should be a trench dug out below the main drains & associated plumbing in order to get then an inch or two deeper?
    May 2013
    Tulsa, OK
    83
    I don't see why they couldn't, but if they have the wiggle room in the concrete grade they can just raise the rebar an ibit and not have to mess with the plumbing since it is in place already.
