Thread: PVC plumbing size for small pump/filter combo
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    I purchased a Hayward vl40t32 pump filter combo for my 18'x48" summer escapes pool. I would like to plumb it in PVC but it didn't come with the appropriate adapter so I am making one to fit. The best option I have is 1.25" union to attach to the suction side of the pump. I am wondering if it would be worth it to run 1.5" plumbing to and from the pump and reduce it down just before my adapter or to just plumb it in with 1.25" on both sides. The pump has a flow rate of 30 gpm and I'm not sure if it will make much difference on that small of a pump over the short(~6' each way) run of plumbing. I've reviewed hydraulics 101, but I can't seem to noodle this one out.
    Ky
    6.7K Pro Series 18x48, VL40T32 pump/filter, Hayward skimmer, TF100, and BBB!
    38,527
    Re: PVC plumbing size for small pump/filter combo
    Likely would not make too noticible of a difference either way. Although if you want to eek out as much flow rate as possible, go with the larger pipe.
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    Thanks Jblizzle.
    If I can't find a better solution than the 1.25" union, then I'll just plumb in 1.5" up to it and reduce down to fit it at the pump. Every thing else will be 1.5" to match a Hayward skimmer and return.
