Results 1 to 16 of 16
Thread: Help with Taylor K-1515 CC FAS-DPD test
    Jul 2013
    Chicago IL
    83
    I just recieved my Taylor K-1515 test ... having a problem :::
    Filled to 25ML
    Added 2 dippers ,swirled , it turned real pink
    Added R-0871 reagent drops and counted -- 21 to turn from pink to clear
    Multiply 0.2x(21) = 4.2
    Then is says to add 5 drops of R-0003 -says it would turn back to pink , but it stayed clear???
    HELP???
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Help with Taylor K-1515 CC FAS-DPD test
    That means you have no CCs, which is a good thing!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,284
    Yup. Also a note that you can use a 10ml sample and multiply the # of drops by 0.5 ... saves the reagents and there is no need for more accuracy than that.
    Jul 2013
    Chicago IL
    83
    So what does this tell me? 4.2ppm?
    Is this high?
    Thanx for the help
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Rynz
    Is this high?
    4.2 ppm is your Free Chlorine (FC) level. Whether is at a good level or not depends on your cyanuric acid (cya) level and also if your water is clear. Do you know what your cya level is?
    See this pool school article: http://www.troublefreepool.com/pool-...ater_chemistry
    38,284
    Depends what your CYA is: pool-school/chlorine_cya_chart_shock
    But, that is certainly not HIGH unless your CYA is near 0ppm.
    Jul 2013
    Chicago IL
    83
    Jeez, now i got to get a cya test kit ....
    38,284
    It really is easier/cheaper to buy the correct kit to start with. {just a note for any future readers}
    Jul 2013
    Chicago IL
    83
    Just gonna order a K-2006 an be done with it
    Jun 2013
    SpringHill FL
    415
    If your ordering a test kit( note i have the k2006) you should get the tf100 with xl and speedstir it has more of the chemical reagents than the taylor kit. I have had to reorder reagents for the cya and chlorine test already
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    So with this, do you just one scoop instead of 2? Just wondering since the volume is less than half as much as before.
    21,000 gallon, IG Fiberglass, Hayward S-244T High Rate Sand filter, Hayward 1 HP pump
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Also the box that comes with the TF is better than the blue box that comes with the Taylor kits. It's easier to use on a daily basis.
    -- Guy --
    Jul 2013
    Chicago IL
    83
    Will do Thanx!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by kmdigital
    Welcome to tfp, kmdigital
    Per the instructions...one heaping dipper or two level dippers.
    Jul 2013
    Chicago IL
    83
    Just ordered a TF-100 ...to end all this water testing madness
    Will be posting test results when it arrives ...
    Thanks for the help , you guys are the best !
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
