Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Why we love our back yard :-)
    Bought our house 10 yrs ago, our landscaping is finally filling in!
    Re: Why we love our back yard :-)
    One more photo
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    May I be the first to officially hate you! Absolutely gorgeous setup there.
    Thanks Mod Squad - you outta see the plumbing! The side of my house looks like a water treatment plant!
    ....And this is why I'm so reluctant to cut that chuck out of the concrete deck plate to fix the broken skimmer! (see yesterday's post)
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I think I love your back yard too!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    I just realized... the Pooch is also in the 2nd photo...LOL.
    Leave it up to old Darby to poo, poolside!!
    Can you post a picture of our plumbing system?
    Sure - can you give me a few days though.....i'm in the middle of a pump upgrade and I have some rework to do first!
    I promise i'll get back to you when I get through these leakage problems i'm having!
    lauriec62's Avatar
    Jul 2013
    Rowlett, TX (Dallas area)
    53
    Wow! Absolutely gorgeous backyard! I'm definitely inspired.
    Laurie in Rowlett, TX (Dallas area)
    16' X 24' AG Doughboy Autumn Breeze w/Madrid liner | Majestic 8000 Blue Wedding Cake Steps
    Pentair Clean & Clear 150 Cartridge Filter | Pentair OptiFlo 1.5 hp pump
    TF-100 Test Kit | BBB is the only way for us!
    3' Buried install by Mendez Pool and Deck (They did a fabulous job!)
    That's fantastic! I love the privacy.
    Our neighbors don't have a solar cover or any clue what they're doing so we don't often have to worry about them being out when we are >
    I'll bet their average water temp has been in the lower 70s. I once heard them shouting about how cold it was. They have no solar cover, no heater and full sun until only 3-4pm.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Lucky dog. . .
    SW Las Vegas, Nevada 10,294 Gal pool, 660 Gal attached spa - 10,949 Gal total. Plaster. 550 Series Hayward Cartridge filter w/ 550SqFt surface area. Flow rate 150GPH, 2.5 Hp single speed pump. Built 2005 with attached spa that sits higher than pool but is on same filtration system.
    I use TFTestkits , Pool Calculator , Pool School - Easy Peasy to do - and am VERY happy with my pool!
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful and tropical
    What is that little ducky-w/sunglasses-thingie in the pool?
    You're done SLAMing when:
    Great attention to detail, Butterfly! Well – would you know I actually don’t even like that Chlorine dispenser (it doesn’t match the theme of the pool much). The only reason I use it is because the amount of chlorine it holds. Once the water temp gets above 86 degrees, it seems to eat up chlorine real fast… that silly looking duck holds about 8 of those giant hockey pucks.
    Jun 2013
    SpringHill FL
    415
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    As per WaterFalcon's request, here's a couple photos of my plumbing system.
    Diagram 2.
    Diagram 3.
    Great, Thanks. How much are in your solar panels. What is typical temp in and out when you use them?
    I meant how much area are in your panels
  20. Back To Top    #20
    Here's the diagram of the layout plan I drafted before I installed my solar panels.
    On days where it's 90F outside, i'll usually see an increase of about 4 degrees over 3-4 hours of running the pump.
    On days where it's 100F + outside, i'll usually see an increase of about 6 degrees over 3-4 hours of running the pump.
    There's many variables that make up the real outcome though. More surface area + more sunshine + more cubic feet moved = more heat.
