Results 1 to 8 of 8
Thread: Do Intex pools collapse
    Jun 2012
    MA
    347
    Has anyone had an Intex pool collapse. Every time someone posts that their pool is out of level you get the warnings of the inevitable collapse. I am wondering if anyone knows first hand of a Intex pool collapsing due to being out of level. I would think if it happened often that there might be damages, injuries and law suits.
    Jun 2013
    Fallsburg, NY
    258
    Re: Do Intex pools collapse
    The Easy Set ones do (the ones with the blow up ring), I have read of a few people that have had theirs dump the water due to unlevel ground. I haven't personally read of any Ultra or Metal Frames that have collapsed yet.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Our ring pool collapsed a couple of times until I got it leveled. I wasn't worried about it as I'm in the country, it all stayed on my property and wasn't going anywhere it could do damage. I'd also seen some u-tube videos and knew that if someone was in it when it happened it would be a short ride across the yard with very little chance of harm. But that's my situation, wide open spaces and only my family in the pool. Other situations and bad things could happen. And with a ring pool you don't have metal poles or walls to worry about. My current pool I made sure I was within 1/4" of level before putting it up.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2009
    S. California
    157
    I'm not an advocate of un-level ground, but will share my recent experience.
    Our 18' Ultra Frame is roughly 1 blue square out of level. Just slightly less, which is probably 1" or so, I've never been concerned enough to measure.
    Our pool gets very hard use by a large group of 8-13 year old kids. On the last day of school we had my daughter's entire 5th grade class over for a pool party. Let me tell you, that pool was jumpin' and rockin' ! After that day it was obvious that my particular un-level situation is not going to be a problem. If it didn't fail that day it never will.
    So yes, do make every effort to get your pool level. But if you have an Ultra Frame and it's 1" or so out of whack, chances are you will be OK.
    Back to your original question, I believe that I have seen at least 1 story of a pool collapsing but don't recall the details.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Jul 2012
    Northwest Alabama
    51
    mine is about 1 or 1.5 inches out of level and i see no fear in it collapsing .....i had it perfest until my dirt i had moved in setteled and thats when it went out of level ....i still do watch it to make sure theres no change in it
    intex ultra frame 14x48 round ag, intex swg, tf100 test kit
    john redcorn's Avatar
    Jun 2013
    B.A. Okla.
    64
    One side of my summer escapes metal frame is 2" lower, kids get wild in there going on the 3rd season now with no problems.
    I need to get a pic of this summer escapes (probably 18' same as mine) I see on the way home from work its crazy wonky and a tribute to how tough they can be. (Unless its only been up a few weeks or something)
    18' Summer escapes with original skimmer + intex pump + intex sand filter w/ Zeolite, Intex SWG. 1x ecosaver 50sqft solar panel with dedicated pump.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    My very first metal frame was given to me by a friend of a friend. It was still set up and I had to take it down and transport it.
    It had been up for 2 years and the way he had set it up was by dumping a pile of sand and leveling it out with a rake and then he put the pool up.
    It was a foot and a half off on 1 side and wonky all around, I was worried the metal frame had been bent by this but after setting it up on my Level pool area it was fine.
    I would never had let my kids in that pool but he had 3 kids and all their friends in there for the first year with no collapse.
    Anyone reading this shouldnt see it as an "Ok" to leave there unlevel pool up. Especially if kids are going to be using it.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    Jun 2012
    MA
    347
    I meant to say the Intek metal frame pools, not the easy set.
