Thread: Help!! Sinking frame!!
    Jun 2013
    Casa Grande, AZ
    9
    Hello all,
    Just a related problem!
    I just filled my pool on a sand base, and recessed 16" cement pavers under the legs of the ultraframe pool. Well, after about an hour when the pool is fully filled-two of the pavers broke in half.
    Now I have the same problem because the side of the pool is sagging on that side. Looks like I will have to jack up the pool to replace the cement pavers with wood. I figured the cement blocks would last longer and be stronger than the wood.
    So, perhaps everyone might consider using wood footings instead!
    Carl in Arizona
    Intex AG, 18x9x52", Krystal Clear Sand Filter Pump Model SF10110 1050 gal/hr max pressure 35 psi
    Jun 2013
    Fallsburg, NY
    258
    Re: Help!! Sinking frame!!
    Just a word of warning, I don't know if anyone has successfully jacked up a rectangular intex pool. The round ones are easy to jack. If you figure out how to do it, please post your method.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Jun 2013
    Casa Grande, AZ
    9
    Yes, I had noticed that no one had posted jacking up a rectangular pool. I will give it a try and post the method if successful. I'm guessing that the blocks I used were not that strong as compared to regular pavers. These blocks are used as "caps" on the top of block walls.
    Carl in Arizona
