Thread: For Jandy Type valve do you block upstream or downstream?
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    In other words, do you set the valve so that no water enters the valve, or do you set the valve so that no water leaves the valve?
    Or....does it matter?
    Thanks.
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: For Jandy Type valve do you block upstream or downstream
    Good question that I haven't thought about before. I assume you mean a 2-way valve? I would think they would work either way, but if you think about a three way valve of the same construction, they are set up so the water enters the valve and then goes to the open leg.
    It will work either way. However, if you plumb it so that water can't leave, the water pressure creates a better seal by pushing the gate against the seal.
    Support the site
    38,305
    What James said, best to have the water enter the valve so that the pressure is helping the seal.
    May 2013
    NJ
    114
    Jandy 2 way valves are clearly marked with an "in" stamped on them so that you install it with water entering the valve for a better seal.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
