Results 1 to 7 of 7
Thread: New Pool Chemicals??
    Jun 2013
    Casa Grande, AZ
    9
    Hello everyone,
    Perhaps this question is listed elsewhere, sorry if I missed it.
    I have a new pool just filling up as we speak and almost to correct level.
    My question is: What chemicals should I put in a new pool? I will be ordering the recommended test kit today, so I have no way of checking the pool currently.
    Any responses will be welcome and very much appreciated.
    Carl in Arizona
    Intex AG, 18x9x52", Krystal Clear Sand Filter Pump Model SF10110 1050 gal/hr max pressure 35 psi
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: New Pool Chemicals??
    Spend some time reading pool school and familarize yourself with what we recommend and what they do. Get some chlorine in there soon as it fills---------(bleach).
    22,548
    Add enough bleach to get about 2 ppm FC in there each evening until you have some CYA in it. Then start dosing for the amount of CYA you targeted. You also need to test the pH and adjust it if it's way off. Do you have a pH test?
    Jun 2013
    Casa Grande, AZ
    9
    Thanks for the answers!
    I cannot test until my test kit arrives. I ordered it today. Went outside and found a new problem. 3 of the cement blocks that I used for the footings on my Intex ultra frame supports Broke in half! I used cement wall "caps" that are 16" long and seemed to be the perfect size.
    I suppose I will need to try to jack up the supports and replace the blocks. Any one familiar with that process?
    Carl in Arizona
    22,548
    There's a couple of threads here where people have jacked up the legs and replaced the pads. You most likely had cinder block pads. One of the others had cinder block pads and they broke. They replaced them with concrete pads.
    Jun 2012
    Howell, NJ
    977
    Yep, cartridge filters are tall, sand filters are round. They don't really make short cartridge filters, as far as I know. You can see some here I don't know if sand filters are shorter, but they are fatter. You can see some here.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Those cinder cap blocks are fragile. You need the concrete pavers. I know my HomeDepot stocks them in the garden section. They are a much stronger block.
    -- Guy --
