Thread: Valves Setup Help
    Jul 2013
    Puerto Rico
    76
    Valves Setup Help
    Hi!
    I am changing my Pump and adding a Salt system & Automation to my pool, so I have decided to change the valves to Jandy-Type valves.
    Now, I have looked at several Valve setups online (Picture 1) and they are different than my Setup (Picture 2).
    I don't have much space where my Pump Station is.
    Any suggestions?
    Thanks!
    J
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    22,553
    Re: Valves Setup Help
    Looks like a 3-way valve at the skimmer and a 3-way valve at the spa would do it.
    Jul 2013
    Puerto Rico
    76
    Thanks!
    J
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Just don't forget that even though jandy valves can close in every direction there is one side labeled inlet that the valve doesn't want to turn to unless you loosen the handle knob and lift the handle over the plastic stopper.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    38,515
    As Kevin said ... it is usually better to have the common pipe always attached to the middle port
