Thread: Anyone want to show me a pic of their sand filter set up?
    I have a partially buried AG 12x24, and the pavestones that they installed the pump aren't level. I need to re-do it. It's gonna be a pain to move and re-set up, so I only want to do it once. Anyone have their a little lower than ground level? Anyone have it camouflaged in an interesting way? It sits a little higher than the top of the pool.
    Yvette in Burleson, TX
    AG 54" 12x24 partially buried
    Re: Anyone want to show me a pic of their sand filter set up
    This won't help you but perhaps you can help me. Any idea if this has to be kept below the level of the outlets or water level and you mentioned your's was above the outlet level. And can we lengthen the hose length? Sorry to bother you if you don't know. [attachment=0:3jd9pjih]pool equip 5050.jpg[/attachment:3jd9pjih]
    Rebecca and Pat Loebach
    Peoria Illinois 61604
    tridoc927@yahoo.com
    http://www.renovatemyranch.blogspot.com
    http://www.embersgarden.blogspot.com
    http://www.drrebeccaknight.com
    Intex Ultra Frame 12x24 52" AG pool. 8,403 gallons
    Intex Krystal Clean Sand Filter Pump with 1,600 gallon per hour flow rate. Intex Krystal Clear Saltwater system.
    Dug 18 x 30 hole, 4' deep, put pool in hole and built retaining wall around it. Currently working on deck surround/topper.
