Results 1 to 8 of 8
Thread: Cleaner for VS Pump and 8 ft depth???
    May 2011
    Tampa, FL
    130
    SO, this is just about as stressful as the whole pool design process!!
    I want a good cleaner for the money, it will have to work on a VS pump (dedicated line) and 8 ft depth.
    Pebblesheen finish and a screen.. issues could be pollen, and paver sand but no large debris. Not sure I want to go the robotic route...but this is our first pool so I'm not sure!
    - Vanessa
    Almost done! 15x30 IG 3ft-8ft deep | SWG | Spa w/ 400K Natural Gas heater | Blue Granite Pebble sheen | JEP 1.5 VS pump | DE Filter | White/Tan/Charcoal Brick Pavers | Bronze Screen | Solar Panels
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Cleaner for VS Pump and 8 ft depth???
    Suction side or pressure side?
    Either way, I would highly recommend ThePoolCleaner. It requires less flow rate than most cleaners so you will be able to run on lower RPM.
    Suction side and pressure sides are good if you want to leave the cleaner in the pool most of the time while a robotic is nice if you want to clean the pool when the main pump is off.
    Mark
    May 2011
    Tampa, FL
    130
    Thanks! Suction.
    - Vanessa
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have the 2x Suction side cleaner and I am very happy with it. Keeps the pool clean and I leave it in the pool most of the time. If you get a lot of leaves in the fall, I would recommend a separate leaf basket or the pump basket will fill up quickly.
    Mark
    May 2011
    Tampa, FL
    130
    Thanks, Mark - I was looking at that model. We will have a screen, so leaves are not an issue, but sand from pavers will be.
    - Vanessa
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I had a pressure side Platinum Legend that came with my house/pool. Was very happy with it, until I bought my Aquabot 4WD. I left the old cleaner in the pool 24/7 (it ran 2 hours per day); it kept pool clean and free of leaves on the bottom. When I bought my Aquabot, I cleaned the pool with the Legend 1 day and the Aquabot the next. The Aquabot got LOTS more sand and stuff I couldn't see. It's also easier to clean. It's also nice to drop it in for 3 hours and pull it out, not having to mess with having pump going. I have since "deactivated" the line that went to the pressure side outlet, so no more need for a booster pump and electricity waste.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Once you switch to a robot you will never go back
    May 2011
    Tampa, FL
    130
    I wonder what the long term, overall price difference is in a suction side with a variable pump and an electric model like the aquabot. The robot is so much more expensive, but its supposed to be cheaper per use, right? Really torn between suction/robot.
    - Vanessa
