Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 47
Thread: Welcome to the New and Improved TFP!!!
  1. Back To Top    #21
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,093
    Re: Welcome to the New and Improved TFP!!!
    Quote Originally Posted by SeanB
    Quote Originally Posted by frustratedpoolmom
    Quote Originally Posted by ktdave
    Very Cool Sean!
    It gonna take some gettin used to, but it looks GREAT!
    Ditto!!!
    Should the "quotes" look that way?
    Working for me.
    Did it work this time? Testing...
    Still can't find the CYA/Chlorine chart....
  2. Back To Top    #22
    12,093
    I'm hitting the quote button when I reply, and see how my posts look? Am I doing something wrong?
  3. Back To Top    #23
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I like the quick reply too? Is that gone forever?
    Where is the CYA/Chlorine chart? I noticed my "Stickys" short cut in my sig doesn't work anymore, so I was correcting it. Found the Pool Calculator but not the CYA/Chlorine chart....
    Help!!!
    (Also, The emoticons were there on my first post on the new TFP but now it's gone.....)
    Please, for the time being hold off on the aritcle suggestions. I have quite a few in the queue, including a simpliifed chlorine / cya chart. It will just take a bit of time to get them all in place. After I am done, I may ask for suggestions for additional topics.
    There is no longer a "stickies" page, which is why the link does not work. The sickies page has been replaced with Pool School which has a much better layout, and easier to follow articles - again still adding to it.
    I show the full list of smilies / emoticons. They look a little small on my screen, which I'll work on but they are there. You may want to clear your cookies and re-load the site. That should restore them for you.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
  4. Back To Top    #24
    SeanB's Avatar
    Mar 2007
    2,622
    You had quotes and smillies disabled in your individual post.
    TFP Founder
  5. Back To Top    #25
    12,093
    Help!!!
    I know, I know....I forgot my TFPFP dose....sorry, I'll try to be more patient :)
    I don't know what's up with these quotes tho?
    Sometimes the emoticons are there and sometimes they're not....
    I found the CYA Chart and while I was perusing around I see what you mean, everything's still in progress.
    So I'll just be a good member and have a dose of TFPFP. :) forgive me....
  6. Back To Top    #26
    12,093
    LOL how do I fix it? I don't recall hitting anything on purpose....(insert blushing emoticon here)
  7. Back To Top    #27
    SeanB's Avatar
    Mar 2007
    2,622
    When you are typing a post, look below the white box. You have options there. One is to disable bb code and the other is to disable smilies. I'm not sure why, but you default seems to be set not to allow those. I'll look into it, but in the mean time, all you need to do is uncheck those boxes.
    On the cya chart, it can still be found here: viewtopic.php?f=8&t=2346
    I know the formatting is messed up. I've got to add in some custom bb code that should correct that.
    TFP Founder
  8. Back To Top    #28
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    At work on Win NT it's kicking me off each time I post or refresh. At work on Vista it's keep me logged on.
    Upgrade looks great.
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
  9. Back To Top    #29
    Mar 2007
    San Rafael, CA USA
    12,082
    I hope there is some way to re-enable the ability to subscript and superscript using CO2 or H+ sequences. Otherwise, all those chemical formulas are going to look really ugly. The ability to subscript and superscript was one very nice feature this forum had that The Pool Forum did not. Superscripting was even used in the chlorine/CYA chart for footnoting.
    It sounds like you are going to add in custom BB code so don't forget to do that for superscript and subscript as well.
    One more suggestion: change the link color to be a lighter shade of blue. The dark blue is barely distinguishable from regular black text.
    Other than the above, the upgrade looks great!
    Richard
  10. Back To Top    #30
    Cool! lookin great!
    If you click on the little blue rectangle next to a thread title with unread posts, it takes you to the first unread post!! And each post is marked as either red or unread by the same white (read) or blue) unread rectangle!!
    sweet!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
  11. Back To Top    #31
    Casey's Avatar
    SW PA
    10,494
    SCHWEET!
  12. Back To Top    #32
    Richardson, TX
    287
    it's like a nice clean pool :D
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
  13. Back To Top    #33
    Apr 2008
    Indiantown, FL
    58
    Hey Sean,
    I just wanted to say thanks and keep up the GREAT work. The new site is looking great and I am sure that you will get all of the bugs worked out but I just wanted to say thanks to you for all of the hard work that you have put into getting this new site up and running.
    Eddie
    Intex 16' X 32' X 52" 14,364 galllon AGP, 16" sand filter & SWG, Pool Rover & Sunrise Journey SPA 320 gallons, TechniChlor 110 SWG
  14. Back To Top    #34
    30,510
    TFP's
    I would like to propose a 48 hour moratorium on complaints about the new forum. I have spoken with seanB and he and the programmer have had very little sleep over the past two days and need some space to regroup and start working out the kinks.
    I think we all can find some things that need fixing but complaining about them now just gives them more things to do (i.e...answer the complaints)
    Let's give him a day or so to recover and then we'll all jump his butt at once!! (I would insert several smilies here...if they worked) :-) :-) :-)
  15. Back To Top    #35
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    Very nice, Sean. The new look i great and it only took a couple of minutes to "find" my favorite features!
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
  16. Back To Top    #36
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Just curious is this the newest verision of phpbb available? if so, version 2.0 is so primative compared to this,LOL
    Finding everything to be so user friendly.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
  17. Back To Top    #37
    12,093
    TFP's
    I apologize if I contributed to the lack of sleep and I shouldn't have complained....
    Whatever was going wrong with my posts is fine now, it must have been something I did....
    The new site DOES look great. Get some sleep guys! (insert HEART emoticon!)
  18. Back To Top    #38
    sammm's Avatar
    North Richland Hills, TX
    257
    Great job Sean. Thanks and keep up the good work!
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
  19. Back To Top    #39
    SeanB's Avatar
    Mar 2007
    2,622
    Quote Originally Posted by lulupalooza
    Yes, this version was over 5 years in development. It's been around in various beta stages for quite a while, but I wanted to wait unitl the final version had been release and around for awhile before making the move.
    If you think v2 was primative, you should see the stripped down version. Ours was HIGHLY modified.
    Glad you like it and thanks to everyone for the kind words. It's been a tremendous amount of work. We aren't done yet, but it's nice to know the effort has been appreciated.
    TFP Founder
  20. Back To Top    #40
    May 2008
    Minnesota
    53
    very nice sean i like it a lot. the only thing that i miss is the quick reply box but i can deal without it.
    20k fiberglass w/ vinal liner, 1Hp magneTek Centurion Switchless Motor, Hayward Pro Series high rate 20" sand filter, Hayward RP 2100 Digital Heater.
