Thread: Pool equipment
    Jul 2013
    Clarksburg, MD
    93
    Pool equipment
    So we are under contract for pool and we are going over final layouts and such and equipment location has come up. I want it on side of house, however pool will be ~100 linear feet away.....would this be too far for pump and heater? PB wants the equipment near pool, and I could landscape around it to hide, but then have to pay for longer electric and gas lines to run.
    Thoughts?
    It should also be noted we will have (2) 18in cascades, and (2) bubblers in tanning ledge. Most likely is a VS pump if that matters
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Pool equipment
    With the right pump it shouldn't be a problem, though you're going to have some heat loss through the pipes on a long run.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2013
    Clarksburg, MD
    93
    Re: Pool equipment
    Yeah, the heat loss was one concern, the 2nd was having to oversize the pump to run the water features.....guess I will go with the PB suggestion...that's why we interview and hire a PB who makes us comfortable, right? He's the "supposed" expert, so I guess in this case I should listen to what he suggests.
    38,548
    Re: Pool equipment
    If you use larger PVC for the longer runs, there is no need to increase the size of the pump. Longer runs of larger PVC is certainly cheaper than longer electrical and gas runs.
