Results 1 to 7 of 7
Thread: Intex hose coupling
    Jan 2013
    Aruba
    229
    Intex hose coupling
    Anyone know how big the intex hose coupling is before it turns into flex pvc 1.5 or 2"?
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Jul 2013
    Missouri
    18
    Re: Intex hose coupling
    I'm not exactly sure of your question but if you're asking about the threads on the Intex hoses I believe they are an odd size of maybe 40 mm. This may be helpful if you're wanting use Intex hoses with other standard size fittings.
    http://www.ebay.com/itm/Intex-Fitting-t ... 3381820428
    16x48 Intex Ultra Frame, stock 1500gph pump with slime bag and Intex 2500gph pump for Hayward skimmer, K-2006 w/SpeedStir, solar cover and wood heater
    Jan 2013
    Aruba
    229
    i want to try to cut the part on the hose before it turns in to flex pvc as an adapter and glue on regular pvc
    Thru wall skimmer,
    Hard plumbed
    Jul 2013
    Missouri
    18
    I understand now but unfortunately don't have an answer. This seems to be a popular way to do what you're describing though.
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    Jan 2013
    Aruba
    229
    thx for the help.i found out there is a thread here where someone cut of the part from the hose before it turns in too flex pvc and he said that it fits in a regular 1.5" coupling,so tomorrow i'm gonna check it out.
    if everything works out i will now have two outlet and two inlet.
    Thru wall skimmer,
    Hard plumbed
    Jul 2013
    Missouri
    18
    Sounds reasonable but I'm not sure regular pvc primer and glue will hold the hose to the pvc pipe. Possibly a two part plastic epoxy may work
    Jan 2013
    Aruba
    229
    i'll have to try it out,anyways it's just the part from the hose where the nut sits and not the whole hose,
    Thru wall skimmer,
    Hard plumbed
