Results 1 to 19 of 19
Thread: Back with another chemical question
    May 2013
    Chattanooga TN
    35
    Our cousins are back - kinda (he's military and gone a lot) - and she doesn't know how to maintain the pool. I tested (at the pool store) today and the chlorine was 0.1. The water was cloudy and kinda green. The salt was also a little low. My question - how much bleach would she need to add rather than shock? The pool store said 3 bags of shock and running the SWG for at least 24 hours. Suggestions?
    15000 GALLON - VINYL LINER - Taylor K-2006
    May 2013
    Chattanooga TN
    35
    Re: Back with another chemical question
    Oh. Also, it's a 15,000 gal pool if that matters. And there's no blinking lights on the SWG so all the rain is the only explanation I have for all this.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Do you have a print out of all the readings?
    Type them in so we can help. I can't see the pool from here...LOL
    -- Guy --
    Do you know what the cyanuric acid (CYA) level is? The CYA level will affect how much chlorine you need. Also, we'll want to understand the pH, and total alkalinity (TA) before SLAMming. Can you test for those? What about calcium hardness (CH)?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    May 2013
    Chattanooga TN
    35
    Wow. Opps! lol. Ill type in my results in a few min. As soon as I get a min to sit down.
    May 2013
    Chattanooga TN
    35
    Total chlorine - 0.1
    Free chlorine - 0.0
    pH - 7.6
    Alkalinity - 70
    Calcium hardness - 50
    Salt - 2840
    Jun 2013
    Hartland, MI
    67
    What's your cya level? And get some bleach n that pool fast before you have real problems.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Sep 2009
    Greentown, IN
    914
    The CYA level is what is needed to determine what your chlorine level should be.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    May 2013
    Chattanooga TN
    35
    If the pool store test didn't give me the CYA number and I can't afford the expensive test kit how can I get a number?
    How much bleach should I start with?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The test kit will save you money but I would add a gallon of chlorine to start with. Pour it slowly in front of the water that is returning to the pool
    Without knowing your CYA, we are a really driving in the dark without headlights. We have no idea where we are going or whats out there. Going to a pool store usually ends in bad test results and a box of chemicals for $100 when all you need is the TestKit and some bleach. I see that last time you came away with three bags of shock that likely made any CYA issue you have worse and it cost $20 for the the Free Test. High CYA will made keeping a pool clear nearly impossible no matter much much store the store sells you.
    The HTH 6-way kit a Walmart has the CYA test but it's not that much more to buy the proper TF kit.
    -- Guy --
    May 2013
    Chattanooga TN
    35
    It's not my pool is what it boils down to. Were it mine I'd cough up the money. :-/
    May 2013
    Chattanooga TN
    35
    Even with the store test results and the strips I managed to keep the pool clear the month that we lived there. I can't convince them to cough up the money when they think their tiny little mini kit does what they need (despite them ending up like this constantly) :-/
    May 2013
    Chattanooga TN
    35
    Will add bleach and see where we are. Sorry I don't have the needed info but any guidance from what I do have is helpful. Thanks.
    May 2013
    Chattanooga TN
    35
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by arwsgirl
    You were told what they need to do ...... the whole concept of what happens here requires accurate test results.
    You can pay for a test kit now or pay the pool store later
    I was hesitant at first to drop $100+ but have saved so much aggravation that it is worth it for that reason alone .... but i save a ton of money on chemicals too
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you are charged with the care and feeding of your cousin's pool in their absence, You really do need a good test kit. Yes, it's not your pool. However, it would be to your and their advantage to be able to cut the ties to the pool store.
    Using nothing but a cheap OTO/Phenol red test kit almost invariably ends in what you have described for that pool. Including being taken for more $$ than you (or they) really need to be spending on the pool.
    Sure, my little Intex has less than 1/3 the water volume that your cousin's pool does. I am able to keep mine looking really good because I went the expense of a good kit. Once you learn about proper pool water care, you will be glad to have a means of accurate testing.
    I go through 1 gallon of bleach every 1-1/2 weeks, and 1 quart of muriatic acid a month in caring for mine. I don't need anything else for my pool, on an ongoing basis. How much do your cousins spend on theirs every time they are home?
    May 2013
    Chattanooga TN
    35
    When they're home? There's no telling.
    When I was taking care of it last time? A gallon of bleach and a bag of baking soda fixed the problem. Not $$$.
    I'm not "charged" with the care. I volunteered since he's out of town and shes got a newborn to deal with and thought I could find some guidance here. I'm beginning to feel like I'm out of luck until I can find the money for the right test kit. I understand the importance of accurate readings but the last time I dealt with this I got by with what I had. Ill try to feel it out until I can find the extra money.
    Thanks.
    Nov 2011
    Albany, NY
    495
    Thanks.
    Where are you located?? Perhaps a kind soul on here would help out a member of our armed forces if they are nearby .... i know i would
    Haywood Sand Filter
    Vinyl Liner
    May 2013
    Chattanooga TN
    35
    Chattanooga. Unfortunately I don't know anyone with a test kit. He's not opposed to getting it - just didn't know. His wife is letting him know about it today.
