Results 1 to 8 of 8
Thread: What's up with cloudy water?
    Jan 2010
    Randleman,NC
    620
    Well,the past 2 yrs. I can keep water balance perfect.But,just has soon has I have people in pool water turn's cloudy.I thought maybe it was my sand.Well,that's been changed.Still cloud's up.Had 7 kid's in pool today.Water level's were last night.FC=5 CC=0 ALK=60"add'd 4 pounds of soda last night"CYA=20"add'd what I had left in jug last"Had my CYA up to 40.But, has been dropping off.We have had alot of rain.Having to backwash alot.Figure that's where that's going.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: What's up with cloudy water?
    I bring my pool to just below shock value when I have guests. I also make sure to keep my filter running during the party and for at least 24 hours after a party. It helps if you make sure your guests don't "p" in the "ool". Having 7 kids is a high demand. You might want to make everyone get out of the pool mid party, test your FC and add chlorine to get it back to near shock levels.
    I installed an outdoor shower for my guests and this had helped keep the pool clear. What is your PH? Your TA seems low.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by kcindc
    PH=7.2..Should increase a little since adding baking soda last night.I was running clorine a little higher when I have kid's over.But,they have such a bleach smell when I run it higher.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Have you tested your CYA since you think it's gone down ? If its low the extra chlorine you add will burn off rather quickly with a heavy bather load and sun.
    Jeff
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by pwrstrk
    Have you tested your CYA since you think it's gone down ? If its low the extra chlorine you add will burn off rather quickly with a heavey bather load and sun.
    I add'd a little last night.Just re-check'd this evening..PH 7.2,,,FC=3,,CC=0,,,Alk=80 now after add's last night.Still need to add more Stab.Got'a pick up another jug.Have ran 3 tablet's this past week because of being out of town.I may just continue using rest of tablet's from container I bought last week.
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by kplaster
    Sent from my iPhone using Tapatalk.
    what happen'd there.
    Mod edit. I fixed it before seeing this post. You added you commend inside his quote, jblizzle
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just make sure you take into account how much CYA the tabs are adding. You figure that out at the bottom of pool calc effects of adding chem's. keep an eye on the PH also.
    Jeff
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    When people complain of a "bleach smell" usually means you smell chloramines. This smell usually means you need to add more chlorine to burn off the chloramines. All the more reason to get everyone out of the pool, test your FC & CC, then add more bleach.
    Karen
