Thread: CYA... sigh!
    JFB's Avatar
    May 2013
    Monréal, Québec, Canada
    96
    CYA... sigh!
    Ok, So I am trying to bring my CYA to 50... I know it should be 70, but I want to bring it up slowly because when the solar cover is on, chlorine goes through the roof!
    I already put in 1.9 kg (68 oz) of stabilizer in my pool 2 months ago but it seems my level is only at 30 (!!) (or slightly below) according to my TF-100 test kit... According to pool calculator, it should be at 38! So I should be measuring/testing 40. Even if I cheat on the up side, I can't get 40. I really see the black dot at 40...
    So, before I put too much of the stuff in there, should I assume it's at 40 and I can't test to save my life or should I assume it's at 30 and adding this stuff is more like art than science?
    Thanks.
    JF
    13.5k gallons, IG, Vinyl, Hayward C3030 Cartridge, Hayward Tristar 3/4hp single speed, Hayward T-15 SWG, Hayward P4 automation, 234 sqft Solex Solar panels. April 2013 construction, Dolphin DX4 robot, TF-100 test kit, Pentair Deck Jets 2.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA... sigh!
    If you can see the dot, your CYA is lower than the line you are on in the comparator.
    38,314
    Re: CYA... sigh!
    Assume it is at 30ppm, that is what the test shows ... it could have been lowered due to rain, splash out, backwashing, etc.
    Maybe the intial dose was a bit off or the pool volume is a little different. The CYA test is only good to like +/- 15ppm I think anyway.
