Results 1 to 7 of 7
Thread: Wondering about pool store advice
    The pool has been working fine this year. A bit of algae earlier that cleared up with a shock and now no CC. I did notice some corrosion on my ladder and looking at my Taylor wheel from my 2006 kit, my index seems to be about -0.7? Pool Store said -0.9? Poolcalculator said -0.8. All those numbers seem too low to me and I understand are a risk for increased corrosion?
    Temp 87
    FC/CC 4/0
    pH 7.3
    TA 80 (pool store got 70)
    Ch 120 (pool store got 130)
    Stabilizer 30 (this year I had to add more stabilizer for some reason)
    Salt 2900
    Clearly I need to add stabilizer (about 2 kg), which will drop my pH a bit as well. Looking at the wheel, it seems that raising my Ch to about 200 will raise the index, so that's also my plan (8 kg), along with a bag of salt to raise my CL to 3100 or so. I must admit that I don't understand why I shouldn't keep my Salt at 2700, since my SWG allows function as low as 2600. Why have salt closer to 3500? save electricity?
    Pool store says 80-120 for TA, but TFP says 60-80 (what I've been doing) and that it's important, but not why it's important.
    I also plan to raise my pH with 1/2 kg of sodium bicarbonate, but I guess I will need to add even more when the cyanuric acid dissolves.
    Lastly, the previous owner left a huge container of something called Gen R 8 "Conditioner", which claims to be "a blended product that recharges sodium, maximizes chlorine effect, protects chlorine and enhances water conductivity", but has no chemical list. What is this and how can I use it up instead of throwing it out?
    Oval pool, Aqua Rite SWG
    80000 l, 22000 Gal
    Vinyl liner, Sand filter, natural gas heater
    Donldson's Avatar
    NW Ohio
    2,904
    Re: Wondering about pool store advice
    Quote Originally Posted by tturkstr
    It's salt. Sodium chloride, and less than 1% CYA.
    http://www.mursattchemicals.com/pdf/gen ... d%20cl.pdf
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,426
    Why not give it to someone you don't like very well?
    A tenant of BBB is do NOT put things in your pool unless you know the outcome.
    a blended product that recharges sodium........ Really?
    22,551
    Since you have a vinyl pool and don't have much CH, don't even give the "index" a thought.
    Keep your pH between 7.2 and 7.8 and the TA between 60 & 80 and it will be fine. Mine's so low that it reads -infinity!
    OK, sounds good. What do I add to increase my pH?
    The pool calculator says washing soda or soda ash, which I thought was the same as sodium bicarbonate. But my bag of sodium bicarbonate says it will raise the TA, and doesn't mention pH. I want my pH up by 0.3, but my TA is fine.
    Thanks
    80000 l, 22000 Gal
    38,343
    washing soda / soda ash is sodium carbonate (note the lack of bi-) or you can use borax or aeration:
    pool-school/recommended_pool_chemicals
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I don't have an SWG so have not followed the exact reasoning for the TA 60-80 being suggested for SWG pools vs TA of 100 for liquid chlorine / bleach pools, but it has something to do with the pH drift induced by running an SWG.
