Thread: inline filter, pentair vs hayward
    Guys,
    My pool currently has one of these http://www.amazon.com/Pentair-R211084-C ... ool+filter and I wanted to get a new filter as this one is quite old. Looking on amazon I see there is a unit from hayward that gets better reviews http://www.amazon.com/W530-Capacity-Lea ... ool+filter
    Question is, are the hose diameters and couplings same between the two?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: inline filter, pentair vs hayward
    They have the same diameters for hose
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    I've used both, and I prefer the Hayward version as well. It's more solidly build and has a more positive, reliable seal. As already posted, they fit the same diameter pipe, but if memory serves, the Pentair has male pipe connections at both ends and uses an adapter to change one side to female, whereas the Hayward has a male at one end and a female at the other. This makes it possible to hook the Pentair up backwards if you aren't paying attention, which is something that can't happen with the Hayward.
    Larry
    Los Angeles, CA -- 22K gallon in-ground plaster pool with spa, built around 1980, replastered around 2009-2010.
    Pentair Intelliflo VS (variable speed) pump and Quad 100 DE filter. Older "MiniMax" gas heater. Pentair Rebel cleaner.
    NO SWG - Liquid Cl only. Taylor K-2006 test kit.
