Thread: pool heater
    elainerader's Avatar
    Apr 2013
    Columbia, MS and Blue Ridge, GA
    120
    pool heater
    Does anyone know of a pool heating system for an in ground pool that runs on solar power?
    (Not a solar cover, a heater that is run by electricity produced by a solar panel)
    If so: cost, effectiveness in winter in the south (it does get into the 30's but only for short time)
    is it even worth it??
    Thanks!
    25K GALLON IG VINYL
    LASER SAND FILTER, Hayward SP2610X15 Super Pump 1.5 HP Pool Pump
    UNDER WATER LIGHT
    14 YEARS OLD, LINER 5 YRS OLD
    22,550
    Re: pool heater
    The best thing to do is get a solar pool heater that heats the water by circualting pool water through tubing panels. They are definitely worth the investment.
    Making electricity using photovoltaic (solar) cells is very inefficient and to have enough of them to power a pool heater would be a very large investment in dollars and real estate.
    Donldson's Avatar
    NW Ohio
    2,896
    Re: pool heater
    About $12,000, the price for a 7 kw grid tie system, if you want batteries add another $3000.
    I really think a propane or natural gas system would be a better bet, or a passive solar system.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2013
    120
    Re: pool heater
    Thanks to both of you!
    25K GALLON IG VINYL
    UNDER WATER LIGHT
