Results 1 to 12 of 12
Thread: 1 1/2 inch pipe question
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    I have a construction thread on here but don't get much traffic and need to know this asap as the plumbers are here. Pool builder says 1 1/2 inch pipe is used at the gunite wall due to fittings and then it is 2inch runs in the trenches. When talking with the pool builder (owner) upon signing contract he said 2 inch minimum which is on our contract. So do the fittings require 1 1/2" ?
    Pool: IG, 8'W x20'L x5' deep, 6000 gallons, Stonescapes Blue Tropics Mini-Pebble gunite pool
    Equipment: Hayward SwimClear 3030 cartridge filter, SP32102EE Tristar 1 HP 2-speed pump,
    Universal H-Series Low NOx H400FDN (400K BTU) heater, SWG = Hayward Aqua
    Rite with Turbo Cell 9, and a Navigator XL cleaner
    Ground break 7/12/2013 Filled 8/6/2013
    22,548
    Re: 1 1/2 inch pipe question
    Yes the fittings require 1½". They should reduce from 2" as close to the wall as possible.
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Thank you.
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Looks like they are putting one 2 inch in and then have two 1 1/2 inch pipes on either side running in the trenches.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You have a fairly small pool so that should be ok, do you know if they are plumbing the skimmer and the floor drain together or separately. Having them plumbed separately and home run to the pad with separate valves is best
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    How do I do the calculation, or guess I am asking, why right at the wall? What if its further away? Or at a T where the return is coming in.
    The intakes are all 2 inch from wall to equipment. Then the return is going 2inch to a T at which point it separates and goes to the returns of the pool.
    I am looking at 1.5 inch run as seen below:
    I do not know how much to do the calculation of how much this affects the return flow, or return psi at each return outlet.
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Quote Originally Posted by Isaac-1
    Its got all the intakes separately piped all the way to the pad, at this time the equipment is not set up on the pad, nor is the piping connected. It looks like we have 3 valves that have one intake and 2 outlets making a T shape. The "Off" looks like it can close off one of the 3 directions.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One more question, where are you located?
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Issac,
    You asking where I am located, as in I am in Houston Tx? (More particularly, we are in an area that is not actually part of Houston, but our neighbor next door to us is, if your asking because of inspection codes.) (Northeast side of Houston if your asking because of weather purposes.)
    Or looking at the piping, few more pictures.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I was asking for weather purposes as those pipes seem very shallow for locations where the ground freezes.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No need to worry with that in Houston.
    Essential Links:
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    After talking to some engineer coworkers, we determined that it really didn't matter if run to the wall or at that T. The small amount of piping wasn't going to make much of a difference. I come home, and the plumber has already cut it all out. So that double work.
