Thread: Testing chlorine
    Testing chlorine
    I have a new pool and the PB gave me a test kit that tests for chlorine, PH, Acid, Alkali demand and TA. Im going to order a CYA test kit but Im wondering, the chlorine its testing for os probably CC not FC right?
    Oklahoma
    30X20 Gunite pool completed in July 2013
    Re: Testing chlorine
    I think I just answered my own question, I googled the Bioguard 1200V kit i have and it says it test for free chlorine.
    Oklahoma
    38,262
    The OTO and DPD tests only really test for TC ... this would match the FC if the CC was low.
    You need to add the CYA test and just as importantly, the FAS-DPD chlorine test which does not have the limitations of the other chlorine tests.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The DPD chlorine test will test for FC but only up to 5 ppm (or 10 ppm if you dilute) and not with great accuracy.
