Results 1 to 14 of 14
Thread: if FC should be 1-3 why is 6 Ok?
    Jul 2012
    Whidbey Island, WA
    397
    have two discussions elsewhere that morphed into many topics that were off topic but they were complex
    but have another question that might remain on topic as is quite focussed
    I see everywhere proper FC range is 1-3
    but you all say for my CYA (80) I should have FC ? 6
    so
    1) if 6FC is Ok, why do I see 1-3 everywhere? and
    2) is 6 Ok to swim in? (CC is zippo)
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: if FC should be 1-3 why is 6 Ok?
    It all depends on your CYA level.
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by JohnT
    got it
    so till I get CYA down, is FC6 ok to swim in?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your CYA is 80 ppm, your FC maintaince level is 6-11ppm.
    Jeff
    SW Indiana
    9,198
    Quote Originally Posted by engrav
    got it
    Yes. It's actually the lowest you should ever let your FC get with 80ppm CYA. Check out pool-school/chlorine_cya_chart_shock
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    6 is ok to swim in.
    Jeff
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by pwrstrk
    6 is ok to swim in.
    Sent from my iPhone using Tapatalk.
    off to town to get some bleach
    thank you
    Jun 2012
    Butler, PA
    336
    If your CYA is 80 in a non SWG pool the minimum your chlorine level should be is 6 your target is 9. I like to stay at a minimum of target for my CYA I get nervous if it falls below. It is safe to swim up to SLAM FC levels which in your case is 31.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by DKT113
    6-11 ppm is his FC range at 80 ppm of CYA.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,881
    To answer this one:
    Because "That's just the way it's always been." That doesn't take CYA in to account and the sad truth is that most people, pool owners and pool store employees, have no idea of the CYA/Chlorine relationship. It's such an old statement that it just hasn't gone away. Kind of like how some people still put butter on a burn or hydrogen peroxide on a bleeding cut.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2012
    Howell, NJ
    977
    It's all because the pool industry refuses to acknowledge the relationship between CYA and chlorine. CYA buffers the chlorine. In fact, there is more active chlorine in tap water (unless you have a well) than there is in a pool that is stabilized by the CYA.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by JohnN
    if tabs over time raises CYA
    and CYA does not go away save by draining
    and CYA requires more and more Cl
    so people shift away from tabs to ?bleach
    and the companies are in it to make $$
    why not make tabs without CYA or with less CYA?
    is this amount of CYA required for stability of the tabs?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If somebody could do that they'd be a billionaire.
    Jeff
    38,251
    You almost had it but let me fix your list:
    -if tabs over time raises CYA
    -and CYA does not go away save by draining
    -and CYA requires more and more Cl
    -[s:3holln0g]so people shift away from tabs to ?bleach[/s:3holln0g]
    -so people blindly go to the pool store when the water turns green and are sold a truck load of other chemicals to try to make the green go away, after iterating on this a few times, the pool store will use some gimmick like "chlorine lock" and tell you to drain a good portion of the pool and then you can start to use the tablets again ... rinse and repeat
    -and the companies are in it to make $$ ... and making a LOT of it by selling magic potions
    Correct, chlorine is not stable so you currently have the choice of adding CYA, calcium (cal-hypo), or lithium ($$$) to make the chlorine stable and safe to handle.
