Thread: The Liquidator - White Buildup in Tubes
    I installed the liquidator about 3 months ago. It has worked well so far. In such a short period, it appears that there is already a white buildup in the tubes. I anticipate that this will clog them eventually. What is going on here? Is there a way to clean them up?
    15,000 gallon quartz finish, in-floor cleaning, Jandy CV580 cartridge filter, Jandy pump, Jandy heater, chlorine feeder and ozone
    22,551
    Re: The Liquidator - White Buildup in Tubes
    Take it apart and flush it with a little muriatic acid and that should clear it out.
    Dont know if it makes any difference but I've ran 12% or 10% chlorine only for 4 years including this season and had no white build-up. Used tygon black tubing but they look clear far as I can see. Put on a section of clear on this year to watch a pinch valve in case it clogged but so far nothing. Pinch valve working great and one less thing to leak..
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Aug 2013
    Austin, Texas
    24
    I had the same problem. Maybe even worse. I also had to disconnect my flow meter because it would scale up with white stuff almost immediatley. I added borates and the problem is gone. I would highly recommend it. Everything runs clear now.
    12,500 gallons, cartridge filter, in ground, pebble
