Results 1 to 16 of 16
Thread: Installing an in-wall skimmer tomorrow, questions about stoc
    My 2650 intex sand filter and hayward skimmer are coming tomorrow. I'm reading up and ready for the install, except I'm a little confused on where the best location is to install the skimmer? I'm guessing it won't replace the current pump intake. If that's the case, do I need to either plug the stock hole, or run some type of connector so as to run both? Simultaneously, or separately? Does that "hardware" come with either the pump or the skimmer?
    Thanks for the help! Anxious to get this up and running!
    Re: Installing an in-wall skimmer tomorrow, questions about
    the most common location i've seen is on the intex logo, close to the seam.
    the original pump intake will no longer be necessary, but you can use pvc to connect it if you want to. that is what i did. when using the skimmer i close off the valve from the original pump intake when i'm using the original intake, i close off the skimmer.
    another option is to change the original pump intake to an inlet for the pool. a third option is to run pipe through the hole for a fountain. or you could just keep it capped off.
    the sand filter will come with plunger valves, adapters to connect them if you have a small intex pool, the large strainer and inlet assemblies. the skimmer comes with a hose adapter, a port to attach a vacuum, and a pool inlet.
    if you decide to cap off, you can use pvc or hose to connect the skimmer to the pump. if you want to use the original pump intake and the skimmer, pvc is the way to go.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by ugafan
    This is what I did, getting the top of the cutout right on the "weld," the seam between the blue liner and the grey top.
    Ditto again. I teed the old Intex outlet into the skimmer line. I was concerned with how much my Hayward pump would draw through the skimmer, and my skimmer vacuum plate doesn't work very well, so I use the Intex outlet as a vacuum port.
    another option is to change the original pump intake to (a second) inlet for the pool.
    If I move my solar panels next season and hard-plumb, I may choose to do this, although I'd need to solve the vacuum issue.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Got the new pump and new in-out-lets in. Cutting was easy, but cut too small on the first attempt, and had to awkward trim the excess, almost stabbing a hole in the wall!
    Didn't get to the Hayward skimmer tonight, a project for the morning!
    CeeElGee, what parts did you use to tie in the original inlet? I zoomed in one your picture, but I'm not sure what all I'd need to pickup.
    What's the issue with your vacuum and your skimmer?
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by peripatew
    Most of the parts are standard stuff. The ball valve/union is a Hayward that came with my Hayward pump & filter. I used a male NPT adapter on the bottom of the union (also the same female NPT threads coming out of the skimmer) to 1-1/2" PVC into a tee that had threads on the perpendicular side, which then got one of these Intex fittings I found on eBay. They are great, allowing me to go from 1-1/2" female NPT to the nice and secure Intex hose connection. That all dropped down into a 1-1/2" hose barb that goes to my pump intake.
    I don't know. Maybe the Hydro Tools vacuum plate isn't very well engineered. I was trying to use it with the strainer basket in place. Maybe I wasn't using it right. Now that I have discovered the secret to defeating the anti-suction relief mechanism on the Intex valve, I'm having better results just using that outlet for my vacuuming. If my water level drops enough and I don't have the weir in place, the pump can suck the skimmer "dry" so to speak unless I open up the Intex valve a bit.
    Gotcha. I had assumed the intex pipes would be standard. Booo!
    Looks like a trip to the Box is needed to make this work.
    Ill need another flexible tube for either the in-wall or intake skimmer, should I order an intex tube, or get something from the pool store?
    I'd like to PVC everything, but really need to stop bleeding money.
    Apr 2013
    Battle Creek, MI
    298
    No, they're not. To most everyone's dismay!
    It depends whether you want to use the Intex connection or just hose barbs with stainless steel clamps. Up to you. I had extra Intex hoses lying around, so it was an easy choice for me.
    Well, good luck with that, my friend!
    Jun 2013
    Ohio
    53
    I would like to chime in here if I may instead of starting another thread. I just got the Hayward thru wall skimmer. I am going to hard plumb continuing to use the original outlet, but I am unsure how to connect the skimmer to the PVC. It looks like it is 2.5" and all the intex connections are 1.5".
    Intex Ultra Frame 18x48; Intex 56671EG 2,650-Gallon Sand Filter Pump; Intex Krystal Clear Saltwater System 15,000 Gallon
    May 2013
    Florida
    21
    I just installed mine this weekend. The outside threads are for 2.5" and it has inside threads for 1.5". I went for the 1.5" treads and stepped it down to 1.25" piping.
    Here are my pictures.
    http://www.troublefreepool.com/1st-p...18-t65523.html
    9 ft x 18 ft x 52 in Intex Ultra Frame
    1,200gal Intex Krystal Clear™ Sand Filter Pump
    Hayward Wide Mouth Skimmer MODEL SP1090WM
    Jun 2013
    Ohio
    53
    Did you have to get another 1.5 threaded piece to come out of the skimmer? It comes with a barbed one for a hose. I'm lost.....
    May 2013
    Florida
    21
    [attachment=0:2vjbvlfj]IMG_20130729_191349_opt.jpg[/attachment:2vjbvlfj]
    I didn't use the barb piece that came with it. The 1st piece is a 1.5 threaded on one end and 1.5 coupler on the other. The next piece is the reducer, 1.5 to 1.25. Then I used one of those prices where you can take apart if you have to take the skimmer off to work on it. I don't know what it is called. Then comes the valve.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by rpeters12
    [attachment=0:e1pbzr9n]IMG_20130729_191349_opt.jpg[/attachment:e1pbzr9n]
    It's called a union
    Done! Took less than an hour, could have done it much faster if I wasn't so stressed about cutting the liner!
    It's working great so far, much easier to vacuum now.
    I didn't reconnect the old skimmer, don't see much of a point right now?
    Got all the needed parts for $25 at our local store, with the ball joint being the most expensive.
    Is the best practice to cut the liner with it full of water?
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by miket0620
    My skimmer (Hydro Tools) came with two gaskets, one for the inside of the pool and one for the outside. After deciding to do the install without draining any water, I located and marked on the outside of the pool exactly where I wanted the skimmer, then punched the top set of holes for the screws through the liner. I added silicone to the entire outside gasket and lined it up with the skimmer, the inside gasket and the inside plate.
    When I had those screws started, I did the screw holes below the water line. Some water leaked out but I quickly had all the screws as tight as possible. Not entirely, though, as I was prevented from finishing the tightening until the liner was cut. With that done, all the screws came tight and I lost very little water. Note: don't forget to have some sort of valve on the bottom of the skimmer before you cut the liner, allowing all that water into the skimmer
