Results 1 to 8 of 8
Thread: Can't get pH right!
    Apr 2009
    SC
    26
    Can't get pH right!
    Please help!!! My pool is a green mess at present . Two weeks ago, it was gorgeous. Then, it rained very heavy every day for two weeks here in SC. Now my pool is a swamp. I haven't put in any bleach because I can't get the pH below 8.8 ( this is by testing with my TFT kit as well as the local pool store). I have put in a total of 30 lbs of pH reducer (from Leslie's), 5 gallons of muriatic acid and yet the pH stays high! I haven't added bleach because theoretically it won't work at this high ph. Before the rain, there was no organic matter on the bottom (I can't see the bottom at present). My current numbers are:
    pH greater than 8.8 ( by the pool store and off the scale with my TFT Kit)
    FC = 0
    TA = 113 (store numbers say corrected to 95)
    CYA = 60
    Pool is in-ground, vinyl-lined and 43,500 gallons. Pump is a Heyward 1.5hp and I have a Hayward 500 lb sand filter (seems to be in good working order) that runs 24/7.
    My salt generator isn't working, so I've been using 12% Sodium Hypochlorite till now. Any and all help will be greatly appreciated. By the way, I recently had a skimmer line replaced as it was clogged - I added this as the only thing that I have done so I can give as much information as possible. Thanks again!
    Bigdog12
    43,500 gal/Heyward 240 sand filter w/ 1hp pump/In-Ground pool/vinyl liner/Jandy SWG
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Can't get pH right!
    The possibility does exist that even the pool store's test was maxed out. You pool could be even higher than that. All you really can do is keep pouring the MA to it, per http://www.poolcalculator.com/, and test/dose as often as you can, giving at least an hour between test/dose cycles, until you see a change.
    I'm thinking that there must be some mistake being made somewhere. 30 pounds of dry acid and 5 gallons of muriatic acid and your pH is still way over 8? How would your pH suddenly get so high? Are you sure that you used dry acid and full strength muriatic acid?
    What was your TA before adding all of the acid?
    What is the pH and TA of your fill water?
    Support the site
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Have you purposefully added Borates?
    30,422
    I'm with JamesW....something doesn't add up.
    How do you think it got that high in the first place?
    Apr 2009
    SC
    26
    I really have no idea how the pH got so high. To my knowledge, no borates were added. Water comes from a well with a pH of 6.8. It has rained a lot over the past month here in SC (avg 1.5 in/day). I did add sodium bicarb as I have done a lot of backwasing to keep the pool level down. I added sodium bicarb to get the TA up from 40 to 95. Any suggestions will be really appreciated!
    30,422
    pH just doesn't jump like that on it's own. I suggest you get a new complete pH test kit. The under $10.00 ones are fine for this purpose.
    I sure would not add any more acid at this point.
    How much sodium bicarb did you add? Are you sure that it wasn't sodium carbonate?
    Support the site
