Thread: Testing water
    Testing water
    I just finished having my pool remodeled (new DiamondBrite, tile, coping) and I'm having a pool company maintain it while the rest of our house is being remodeled.
    I've always had a hard time reading the results of the drop tests w/ the slight differences in color shades. Has anyone tried a digital tester? What is the easiest, most accurate way to test water, without guessing at color shades or having to drive to a pool store?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Testing water
    Welcome to tfp, CHooper
    The best test kits are discussed here: http://www.troublefreepool.com/pool-...kit_comparison Although they are drop based, only one test (ph) requires seeing color shades. The rest are just counting drops until the color goes from pink to clear, etc. Not difficult at all.
    Digital testers sound great, but the ones that do okay cost a lot. In addition, all digital testers need to be calibrated regularly.
    May 2013
    Bay City, Michigan
    283
    Re: Testing water
    http://www.youtube.com/user/tf100testki ... sults_main
    There is a link for videos on the tests that are included with the TF-100. Only the OTO and PH test are color matching. The accurate chlorine test (FAS/DPD) is counting drops. The videos show the CYA test, FAS/DPD chlorine test, the OTO Chlorine and PH Test, the Total Alkalinity test, and the Calcium Hardness Test.
    Quote Originally Posted by CHooper
    For your own safety, no more using accurate and pool store in the same post.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Jun 2013
    Fallsburg, NY
    258
    Re: Testing water
    +1 tf-100 or Taylor K-2006 for very easy to read tests. SpeedStir makes testing even easier.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
