Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Beginners advice (1 week in)
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    My above ground pool has been opened a week. I've used the pool calculator and it seems everything is in check. I ordered the TF-100 kit and hopefully it will arrive soon.
    In the meantime, here are my levels for a 4625 gallon Intex Ultra Frame Pool with a filter pump and SWG.
    These results are with a reagent drop test.
    FC 2.0
    CC 0
    pH 7.2
    TA 80
    I've used strips for the results below:
    TH 100
    TC 1
    FC 3
    pH 7.2
    TA 80
    Stabilizer 40
    The water looks clear. I had to adjust the pH (adding muriatic acid) because it was running at 7.8 and the TA was at 130 and is now down to 80 and the pH is a little low at 7.2.
    Does anyone see any concerns or have any suggestions? I added 15 oz of bleach this evening also (according to the Pool Cal).
    Is my stabilizer at a good level? I added it a week ago (1 pound of cyanuric acid).
    Hopefully I will have more reliable numbers once the TF-100 arrives.
    Two weeks ago I knew nothing about this "stuff." I've followed the advice and read and re read Pool School. It does help.
    Any suggestions or advice or reassurance is appreciated.
    Thanks
    4600 gallons, Intex Ultra Metal Frame 14' round 4' depth, SWG, cartridge filter pump, 2500 gph, Pool finish date: 7/16/13.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Beginners advice (1 week in)
    Congrats.
    If your water is clear your doing something right. When the good kit comes post those results. You know how we fill about the test strips.
    With the CYA at 40 (check it again when the good kit comes) keep your FC at 3-7 ppm. Don't let drop below 3 ppm.
    Keep up the good work.
    Jeff
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    I do know how everyone feels about the strips. I've gotten different reading using the drops vs the strips. I find the strips hard to read when comparing the colors plus the increments go up so much you don't know a very exact reading.
    I'm handing skimming everyday, testing everyday and I'm waiting on a vacuum to arrive so I can keep the bottom cleaner.
    I'm actually enjoying the chemistry piece of the pool. I have a stressful job (working with kids in a psych hospital) and couldn't wait to get home and just float around in the pool. Most relaxing moment I've had in a while.
    Thanks for the encouragement. My "good work" is all due to this site.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I agree with pwrstrk, recheck that cya (and other parameters) when your kit comes. If you have only added a lb of stabilizer, then your level should be 26.
    Also notice how your strips said FC was greater than TC. That is impossible...TC=FC+CC
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    When you get the TF 100 compare those results with the others.
    You've got a good grasp on things. I agree with you. This is the best pool forum.
    Jeff
    Jun 2013
    Fallsburg, NY
    258
    Since you're using an SWG, you should probably increase CYA. Read pool-school/water_balance_saltwater_generator You're in the right range for TA, but as you adjust your SWG (with increased CYA levels, you will be shooting for a slightly higher minimum FC. pool-school/chlorine_cya_chart_shock
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Thanks!
    I felt like the CYA should be higher but will confirm when the kit arrives.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    With the SWG you want the CYA to be around 60-80 ppm. You won't be able to test accurately until the TF100 comes. If you have to add more CYA which you prob will, remember the CYA will lower your PH some. The pool calc will tell you how much at the bottom. Effects of adding chem's
    Jeff
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Once I test with TF-100, I will post the results and let you all guide me as to what I should adjust first.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Will do. Although I think you already have a pretty good idea.
    Jeff
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Okay, I received the TF-100 kit today.
    Here are the results:
    FC 7.5
    CC .5
    TC 8
    pH 7.2
    TA 110
    Stabilizer 20
    Obviously I need some adjustments because it looks like the stabilizer is too low and the FC is awfully high.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would raise the CYA level to 60-80 with the SWG. . It will also lower your PH. I would raise PH up then add the stabilizer. Raising PH also raises TA some. Or you can tackle the PH last. Your choice.
    Look at the pool calc at the bottom, effects of adding chem's. it will tell you how much of x amount of stabilizer will lower PH.
    Jeff
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Do I need to panic over the 7.5 CF level? Should I not run the SWG pump this evening? I have been running it 4 hours a night.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your FC is in range. CYA of 60 ppm your range is 5-9 ppm
    CYA of 80 ppm is 6-11 ppm.
    Jeff
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    I'm adding CYA now (put it in a sock and hung it from the ladder in front of the water return). (adding 31 ounces is what the Pool Calculator said and it should have minimal effect on the pH but I will check everything tomorrow and probably starting getting the pH up.
    I'm waiting on a pool vacuum to arrive. There is a little dirt on the bottom in places. I'm keeping everything skimmed.
    I'm trying to just enjoy the process. I know I'm learning as I go along.
    Thanks for the advice. I'm sure I'll need more tomorrow.
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Okay so I have some different numbers today after adding soda ash and stabilizer.
    FC 5
    CC .5
    TC 5.5
    TA 110
    CH 70
    CYA 60
    pH 7.2
    What should I adjust next? I'm thinking I need to get the pH up to 7.5.
    Jun 2013
    Fallsburg, NY
    258
    Your TA needs to come down, so don't adjust pH up, it will rise by itself with the SWG turned on, you can also accelerate the rise by aerating the water (turn your outflow so it breaks the surface). Wait for it to rise to 7.8 and lower it back to 7.2 using Muriatic acid. Keep doing this until TA is in range (60-80), then stabilize your pH at 7.5-7.8.
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    How do I aerate an Intex Ultra Frame Pool?
    Jun 2013
    Fallsburg, NY
    258
    Did yours come with an aimable eyeball on the outflow (the one that shoots water back into the pool)? If it did, just point that up toward the surface so it agitates the surface, if it didn't, there are other creative solutions, like disconnecting the hose from the outlet on the outside of the pool (assuming you have a shut off valve) and securing that to the top rail so the outflow shoots into the pool from above the waterline.
  20. Back To Top    #20
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    A good bit of swimming and splashing can aerate some or you can search this forum for pool cooler. Basically redirecting some water into the air "sprinkler" fashion.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
