Results 1 to 8 of 8
Thread: Adding DE after EACH backwash while shocking?
    Quote from TYGSBIASO sticky: "DE filters will often need to be backwashed a couple of times a day for the first day or two."
    Does that mean I have to add 12 scoops of DE medium (my normals) each time I backwash? That's a lot of DE. Just want to make sure.
    BTW, shocking pool for first time in 4 years! Never had a bit of algae until this week
    39,000 gal 48 x 22 gunite/pebble, SWG
    Pentair Intelliflo
    Jandy Aqualink RS; Jandy 60 DE Filter
    Polaris 280 Black "Manta Baby"
    3 Jandy WaterColors LEDs
    38,242
    Re: Adding DE after EACH backwash while shocking?
    Yes. You can not run water through the filter without DE for more than a few minutes (especially when the water is dirty) or you will clog up the grids with debris.
    Is 12 scoops the recommended weight? After a backwash you usually only want to use about 80% of the recommended amount since the backwash is not that thorough:
    use-and-care-for-de-filters-t4086.html
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Have to add if you backwash to have something to catch the rest.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would say you only need to backwash if you are getting the pressure increase that justify the backwash that removes your DE. I have a Hayward that can be bumped to "re-generate". It redistributes the DE so the pressure go back down. I have not truly "backwashed" my filter. I take it apart and clean it. The need to completely dump and re-fill only happen if you are filtering a "swamp" with a DE.
    I have good luck if I shut the pump off, let the algae and junk sink to the floor of the pool and then vacuum to waste.
    that said, I have had to change the DE several times in a day IF the swamp needs to be cleared. Yes, it took a whole bag of DE to do this but DE is relatively cheap (relative to other filter media costs)
    -- Guy --
    The company that installed my pool instructed me to add 12 scoops of DE after each backwash. If I can get by with less, I'd be happy.
    I don't have a swamp. Just algae growing on the walls a little bit. Had my nephews in town last week; despite the outdoor bathroom, not sure they ever used it.
    My test results this morning:
    FC 4
    CC 0
    CYA 60
    Ph 7.4 (lowered for shocking)
    Added bleach and am waiting to test again. TPC recommended a shock value of 18ppm. Will brush the walls in about an hour.
    Pentair Intelliflo
    38,242
    I would highly suggest you weigh the DE yourself ... there can be quite a variation in the amount of DE mass fits in a container depending on how well you pack it.
    Ok, so I need 6 lbs, according to the manual. The manual says nothing about adding less for a backwash; in fact, it refers back to the chart in the start up section. Can I get away with 4.8 lbs?
    Pentair Intelliflo
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I looked at the instructions for Jandy DEV 60 and it appears they assume you back wash the filter 1-5 times until 100% of old DE is washed out of the filter.
    I guess is depends on how clean the backwash made the filter.
    I find I am happier just opening the filter and cleaning the grids (fingers in my case) with a hose before rebuilding the filter and adding a 100% charge that I know is 100% clean. It only takes me 30 minutes of so to do this. I do NOT have the same filter.
    -- Guy --
