Results 1 to 7 of 7
Thread: Test results
    Test results
    The water was cloudy the other day, but now has cleared up. This is what I got.
    I have a plaster pool and use the Hayward swg.
    cl - 5
    ph - 7.5
    cya - filled up the tube and the dot was still slightly visible
    ta - 60
    fc - 1.5
    cc - 0
    Thanks all
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If your tube filled up, it means you have less than 20 ppm of CYA, and you need 60-80 for a SWG.
    Using the pool calculator, determine the dosage to raise your CYA to 60. Add that in your skimmer, and don't backwash or clean your filter for a week, while it dissolves. Then retest. You can always add more, you don't want to overshoot.
    To me, there is an inconsistency in your numbers. You show CL 5
    cc - 0 and
    FC 1.5?
    That doesn't make sense. Can you confirm?
    Your CYA level is way too low, probably around 10. You want CYA to be between 60 and 80 with a SWG.
    I may have done the FC and the CC tests wrong and will try them again tomorrow. I was thinking the same thing.
    How do you raise the cya?
    I saw the pool calculator in your sig Jason and now know how to raise it.
    That calculator is awesome by the way.
    11,969
    You buy CYA aka Cyanuric Acid or at Walmart and pool stores might be labeled as Stabilizer.
    Use the pool calculator to determine your dosage based on your pool gallons (I don't know what your pool size is) and then put it in your skimmer and let it dissolve in your filter, could take up to a week to fully register the total amount on a test. That's why you don't want to clean or backwash a filter during that time as you will lose CYA you just put in... Always under dose, you don't want to overshoot and then have problems resulting from CYA that's TOO high.
    11,969
    You can also put the CYA in a sock and tie it by a return.
    I also read on here they sell a liquid form, not sure where that is available for purchase.
    Just make sure you are buying Cyanuric Acid.
    11,969
    Quote Originally Posted by michael2113
    That calculator is pure magic
