Thread: In-wall Skimmer on Intex 30" deep metal frame pool
    Has anyone installed an in-wall skimmer on the shallower Intex metal frame pools? I'll be setting up an Intex 12' x 30" metal frame pool soon, and coming from an in-ground pool background I want to set up the new pool from the get-go with some "big pool" features that I'm used to. I've seen the posts where people have installed the skimmers above the seam to preserve depth on their deeper pools, but would like to know if anyone has done so on a 30" pool and what the results were. I'd like to be able to get every drop of water possible into the pool. Thanks!
    Intex 12' x 30" AG metal frame pool with Intex Krystal Clear 1600 sand filter/pump. 1800 gallons. Southern California.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: In-wall Skimmer on Intex 30" deep metal frame pool
    Welcome to tfp, dberber
    I see no reason you couldn't follow the "above seam" skimmer installation approach.
