Results 1 to 8 of 8
Thread: should I be concerned at Chlorine level (too high)
    Jul 2011
    SW France
    105
    Just arrived at our house - which some of you may already know is rented out most of the time - to find a clear pool but with FC at 15-16ppm
    I left the pool open in the sun all day today - 5 kids been in and out most of the day - temperature of pool is 28C, temp in the shade is about 35C, so bright sunlight. Tested using DPD kit this morning and the FC was at 15ppm. Tested the pool this evening and it was still at 15ppm. I thought it would have dropped but it seems not.
    CC - 0
    CYA level is 60
    TA is 130
    CH is 140
    PH is about 7.6-7.8 but reckon it's on the high side due to chlorine - although marginal.
    I have installed a new Pool Pilot digital, which I am still trying to fine tune to produce the right amount of chlorine, (I've also installed a new Hayward Max Flo VS pump, so lots to play with!) The pool cover was on for 24hrs including during the day preceding my 15ppm result, so would this have raised the FC to this level so quickly? Also, how long can I expect the chlorine levels to remain above 3ppm (reckon this is about right default level? or should it be about 5ppm) with the cover off and the sun shining?
    SWG - Exterior
    12x5M
    90,000 Ltrs /24,000US gallons
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: should I be concerned at Chlorine level (too high)
    I assume you mean CC not FC where you show FC=0
    Is the SWG running?
    As to suggested levels refer to the CYA / Chlorine chart pool-school/chlorine_cya_chart_shock which shows you are above suggested, but still way below shock level, so swimming should be safe.
    I would suggest you test again tomorrow and post your results, and confirm if the SWG is running / running too many hours per day..
    Ike
    Sep 2009
    Greentown, IN
    914
    Plug your numbers into http://www.poolcalculator.com/.. don't forget to make sure your pool size is changed at the top. It will show you what your pool test levels should be.
    Looks to me like 15 FC is below your shock value, so safe to swim in.
    With an SWG and a CYA of 60, your FC should never be given a chance to drop below 3. I would keep it a bit above that for safety sake and peace of mind.
    If your SWG is running, it will keep your FC levels up. With a FC of 15, you may want to turn your SWG off for a day or two... don't forget to test, and let your level come down a bit.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2011
    SW France
    105
    Quote Originally Posted by Isaac-1
    Is the SWG running?
    sorry, yes...typo... CC is zero FC is 15 have edited it, thanks!
    SWG is not running, as am trying to lower chlorine level. Will test again tomorrow morning and night and report back to see if the level drops at all. Shock levels according to the chart are 24ppm, so well below this.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    38,237
    How are you measuring a FC of 15ppm with the DPD test that maxes out a 5ppm?
    If you are diluting, you are losing accuracy and that may be why it appears to not be dropping.
    Jul 2011
    SW France
    105
    Am using Taylor K2006 DPD kit that should be capable of measuring way up the scale. I am currently doing it in a 10mm water sample.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    38,237
    So you are using a powder? That is the FAS-DPD kit ... the DPD test is different ... thus the confusion.
    Jul 2011
    SW France
    105
    my apologies...I knew that something was missing!! Yes, powder in a 10ml solution then adding drops until solution goes from pink to clear. just done a test this morning - and if I was doing overnight shock test, I would be happy. Overnight no change from 15ppm, but then I kinda expected that. It does confirm though that there is very little if any demand on the chlorine.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
