Thread: More Chlorine required to maintain higher FC?
    Hey all,
    I've been pondering something, and was wondering the answer:
    Lets say I have two identical pools,
    Pool "A" has FC=4, CYA=40
    Pool "B" has FC=8, CYA=70
    I'm referring to ideal levels, listed on the FC/CYA chart here http://www.troublefreepool.com/pool-...ya_chart_shock
    Question: Will it require more chlorine to maintain Pool "B" at 8 FC, than maintain Pool "A" at 3 FC? I guess the real question is does chlorine leak out of a pool faster at higher levels?
    Michael
    33,000 Gallon, 20x40 Vinyl Inground, 500sq feet cartridge filter, 3/4 HP Hayward Super Pump, Installed 6/2013. Central Virginia, USA
    May 2013
    North East Ohio
    959
    Re: More Chlorine required to maintain higher FC?
    Actually the opposite it true...Pool "B" should consume less chlorine over time.
    Although 70 CYA is a bit high especially when you have to SLAM
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
