Results 1 to 15 of 15
Thread: Hayward's DE filter will not vent air/water
    Jul 2013
    Mesa, AZ
    15
    My Hayward de filter air pressure relief valve will not release air or water. It turns but the flow of air/water is not there. Any suggestions on how to fix or does it just need to be replaced?
    40k Pebble Pool with Spa Spillover
    (2) Hayward Pro-grid 6020 DE filters
    (2) Hayward pumps 1.5 hp, 1.60 sf, 2.4 thp
    Hayward H series
    TF-100 test kit
    Jun 2013
    SpringHill FL
    415
    Re: Hayward's DE filter will not vent air/water
    Unscrew it from the top of the filter and use a tooth pick to clean out the gunk that has built up in the small opening( happens to me alot!!!)
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    Mesa, AZ
    15
    Quote Originally Posted by FamilyGuy
    I have tried to unscrew the top, does not seem to want to budge any suggestions? I had a sand filter that came with a tool.
    Hayward H series
    TF-100 test kit
    30,421
    The relief valve will unscrew independently from the filter top, if I understand what you are saying.
    Jul 2013
    Mesa, AZ
    15
    My luck with plastic, is it usually breaks.
    I will try again. The instructions say to remove the entire top to twist counterclockwise , using the flats. Do you know if it is couterclockwise?
    Hayward H series
    TF-100 test kit
    Jun 2013
    SpringHill FL
    415
    Can you post a picture of the valve assembly?
    Nathan
    Jun 2013
    SpringHill FL
    415
    If it is a top mount pressure relief valve to remove it you turn it counter clockwise
    Nathan
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    http://www.hayward-pool.com/pdf/manu...rid-DExx20.pdf
    Were you looking to take just the MAR off, or the whole lid assemble to the filter? I think you could take the clamp band off the belly of the filter, lift the lid off and then reach inside and clean out the bottom of the gauge. I think the removal of the MAR is uncommon and it requires a very large wrench.
    I don't have this filter but another Hayward DE. I do not have a MAR.
    -- Guy --
    Jul 2011
    Monmouth County, New Jersey
    81
    I have one on top of my Hayward DE filter and it is also clogged I think. It used to shoot air out and then really shoot water out with force. The air still comes out when I have it open but only a trickle of water comes out.
    I am afraid that if I break it we are in big trouble. My pool guy is so busy I have no idea when he could get here. He is redoing everyone's pools and equipment after Sandy and is reportedly swamped. Anyone who flooded lost all their equipment and many pools had damage
    We didn't flood, we only had a really really full pool.
    Should it be easy to turn and I am assuming that I would do this with the filter off. I read somewhere that if you don't do it right you can wind up with it flying into the air.
    I wish I was a little more daring with this stuff. I just hate to break it.
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Are you willing to release the belly band? The big black metal one. It's a 3/4 inch socket wrench that's required. Remove the bolt and spring, remove the clamp (tap on it to make it loosen up) and then take the head of the filter off. I have heard some people turn the pump on for a second to loosen the lid. My lid/head comes off pretty easily but is a little heavy.
    -- Guy --
    May 2013
    NJ
    114
    If it were me I think I would just open the vent with the pump off and shoot a little compressed air in to clean it out.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Jul 2013
    Mesa, AZ
    15
    Here is a picture of mine. I have taken lid off many times to service de filters, just thought top would come off by itself. I will try some compressed air too.
    Hayward H series
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    That small piece with the integral red handle should just unscrew. Page 10 of the manual techguy linked to shows it as a separate piece. Don't lose the O-ring.
    Jul 2013
    Mesa, AZ
    15
    O.k. So the vent can be separated from the rest of the unit, BUT the "wing nut" will fall into filter, luckily top comes off and wing nut was on top of filter.
    Cleaned out, and replaced, including the o ring, I lost somewhere. I had it but it must have come off one of the many times I had to reseat the whole thing, trying to get a tight fit.
    Hayward H series
    TF-100 test kit
    Jun 2013
    SpringHill FL
    415
    Good to hear your making headway on it. Stinks about the oring though
    Nathan
