Results 1 to 10 of 10
Thread: skimmer filter basket pops up
    Jun 2008
    NJ
    12
    My skimmers filter basket keeps popping up when the pump turns off.
    AG pool with a cartridge filter (24"?).
    The problem is, sometimes it will not set back in correctly.
    I happened to catch it today as the timer turned it on. I saw the return line bubbling.
    What can cause this "burp" when the pump turns off.
    thanks
    5100 gal Above Ground Intex Pool with cheap filter and pump
    TF-100 Test Kit
    Jul 2007
    Suwanee, GA
    528
    I have a small rock in each of mine to keep them down.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Mine turns to lock into place....
    Jun 2008
    NJ
    12
    I worry about that getting in somehow .
    I still might try it.
    Quote Originally Posted by crabboy
    TF-100 Test Kit
    Jun 2007
    SF Bay Area
    441
    kenshell,
    Maybe try not such a small rock. Choose a rock that is larger than any of the piping that the rock might get caught in. This way you won't be able to send a rock to your pump impeller.
    http://ths.gardenweb.com/forums/load/po ... 13340.html
    http://www.poolforum.com/pf2/showthread.php?t=3964
    http://www.poolforum.com/pf2/showthread.php?t=2416
    (I tried searching this forum, but had too many posts to review when I searched for "basket", "rock", etc. Sorry for the links to those "other guys".)
    Here is a commercial solution: http://www.coolpoolsolutions.com/
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I like the idea behind the Skimmer Buddy, but if you used that, I don't see how you could use a skimmer sock, and I do like my skimmer sock!
    My skimmer basket pops up sometimes, too. I make it a point to check my skimmer every night to (a) see if it's popped up, and (b) to see what kind of **** is in it. Had a hornet, a carpenter bee, some Japanese beetles, and a grasshopper in it tonight - pretty good catch.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    11,969
    Quote Originally Posted by MikeInTN
    Deepfry em and you've got a good snack....
    Jun 2008
    NJ
    12
    Re: skimmer filter basket pops up
    So I bled the filter housing and it is much better.
    thanks to all
    TF-100 Test Kit
    Exton, PA
    249
    withdrawn. Have a lifetime supply of rocks.
    problem solved.
    thanks
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Aug 2008
    Phoenix, AZ
    26
    I keep a rock in mine.
    15,000 gal Freeform Salt Water (SWG), Pebble Sheen with in floor cleaner. Hayward 1.5hp pump and 425sq ft Hayward Cartridge filter. 35sq ft Waterfall with separate 1.5hp Hayward Pump.
