Thread: Vacuum
    Jul 2013
    Lake Jackson, TX
    5
    Vacuum
    When I filled up my pool, using city water, I had lots of sand in my water and the vacuum I currently have will not work to pick it up because the sand is so fine. Would like suggestions for a new vacuum without spending a lot of money. I have an Intex Ultra 18' x 48". I still have the original pump that came with it which I also need to upgrade but can only do one thing at a time, spent a lot of money getting the ground leveled. Thanks!
    18'x48" AGP, SandPro 75 Pump and Filter system, Constructed 7/2013, Intex Deluxe Skimmer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Vacuum
    Welcome to tfp, rose1994
    Which pump/filter did your intex come with?
    What vacuum do you have?
    Most likely your pump is small for a suction side vacuum. Any other type of vacuum (pressure or robot) is going to cost a lot, so a pump upgrade and cheap suction side vacuum head like the triangle in this pic: http://www.troublefreepool.com/image...nualVacuum.jpg may be your best choice.
    Jul 2013
    Lake Jackson, TX
    5
    Re: Vacuum
    Thanks for the welcome, this site has already helped me tremendously. My pool came with the Krystal Clear Model 635T Filter Pump. So if I buy a new pump I could use a vacuum that connects to the pump?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Vacuum
    Yes, many people have had great luck with the intex 2650 sand filter/pump.
