Thread: what to use to raise CYA
    What product do you use to raise CYA?
    Oklahoma
    30X20 Gunite pool completed in July 2013
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: BBB can't possibly be this easy?? One question though...
    Quote Originally Posted by thelorib
    You use CYA to raise your CYA. It is normally packaged as Stabilizer or Conditioner. It get mine at WalMart for 4# for $15. It has a purple lid. We call it CYA for the active ingredient isocyanuric acid and to make it easy to type.
    -- Guy --
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: what to use to raise CYA
    To add the granular CYA to the pool, place the granules in a sock, old T-shirt, or similar implement. Then tie it up and either place it in the skimmer or suspend it in front of a return jet. The handle on an old bleach bottle filled with water makes a great and portable anchor from which to suspend the sock (or whatever you are using) in front of a return jet.
    Use the Pool Calculator to determine the dosage amount.
