Thread: Removing the last 2" of water
    Hi, I have a 24' X 54" deep above ground. I have pumped out the majority of the water (due to swampy water) with a high speed water pump. My question is, how can I get the last 2" of water out of pool? I need to clean walls and bottom to remove remaining algae etc..Thanks in advance!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Removing the last 2" of water
    Welcome to TFP!
    There is really no advantage to getting rid of it or for that matter draining at all to get rid of algae. Getting the liner to fit right after draining can be difficult.
    Fill it up, follow the instructions in Defeating Algae and your water and liner will be sparkling clear.
    Sep 2009
    Greentown, IN
    914
    2" isn't very much water in a pool that size. I agree with JohnT.. fill'er back in with water and see the pool school link to learn how to SLAM it.
    If you don't have a good test kit... get yourself one that is recommended here http://www.troublefreepool.com/pool-...kit_comparison. You will be glad you did.. it is worth every penny in the process of clearing a pool.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Thanks guys!
