Thread: Uprights not plumb
    Jul 2013
    Downers Grove, IL
    11
    Uprights not plumb
    I just had a Mighty Sun 15 x 30' 52" oval installed over the weekend.
    I have a couple of the uprights on the short end out of plumb, one leans away from the top of the pool about1 - 1 1/2" and another leans into the top of the pool about 3/4". there are a couple other that are out but no as much (1/4 - 1/2") the uprights and buttress's are plumb on the long ends, it is just the short that are out.
    Is this a BIG concern?
    I appreciate any feedback.
    15 x 30' - 52" oval Mighty Sun
    1.5hp pump - cartridge filter with frogger.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Uprights not plumb
    Welcome to tfp, kpaveza
    Often out of plumb uprights are indicative of a pool being out of level. How is the vertical level (water level to top of uprights) around the pool? It should be less than 1".
    Jul 2013
    Downers Grove, IL
    11
    Finished filling it up last night. Installer said it's not a problem (being out of plumb)
    He's coming back today. The water level does look to be about 1 - 2" higher on the skimmer side, which is also where the uprights are out of plumb.
    Also, I did notice the wall seam is not completely covered by one of the uprights, is this a concern?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, you should not be more that 1" out of level on a new install (many installers shoot for 1/4"). Might be worth posting a pic.
    Casey's Avatar
    SW PA
    10,461
    Take several pics of the uprights, water level across the whole pool, the skimmer, far away... Any and all pics you could include would help us help you.
    Jul 2013
    Downers Grove, IL
    11
    I appreciate the feedback, I will try to take some pictures when I get home. I will advise what the installer says also.
    He did say that most mfg., allow up to 2" out of level, but they try to stay under 1/2"
