Thread: Looking at Dough Boy pool
    We are looking at getting the Palm Shore oval by Dough boy. We are also looking at using the expanding liner to drop some of the bottom down 2-3ft.
    Has anyone done this with their dough boy?
    Just looking for any thought on this. New to having an above ground pool.
    thanks
    Apr 2009
    Oklahoma
    51
    Re: Looking at Dough Boy pool
    Yep. We have a deep side of about 6 1/2 feet on ours. Wouldn't have it any other way. My build is the link in my signature.
    32' Doughboy Desert Spring (Blue Bayou liner) Buried with Deep End
    300# Sand Filter, 1.5 HP Pump Hayward
    My Build: making-the-jump-to-a-doughboy-from-our-old-intex-t56425.html
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I don't have a Dough Boy but I did put an expandable liner in and put a little extra depth in my round pool. Very glad I did.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, rdefino
    Put me on the list of highly recommending a deep end. It should work fine with that pool. Deep ends are very common on Doughboys.
    I've often thought about how much expense would be involved with installing an expandable liner in my pool. Really wish I had done it initially. It's not worth the cost until I need to replace the current liner. I also want to bury the pool itself, but the hard-scaping we did won't allow for it without major finesse.
    Get the deep end!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
