Thread: backwash
    backwash
    When do I need to backwash?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: backwash
    When filter psi rises about 20 to 25% above clean filter psi.
    Welcome to the forum
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: backwash
    Welcome to TFP!
    It depends on what kind of filter you have. Cartridge filters are not backwashed. Only some DE filters can be backwashed, but all sand filters required periodic bakwashing. General guidance is at a 25% rise from normal pressure, but I tend to just backwash mine whenever I need to get rid of rainwater from the pool.
