Thread: Pool dig help
    Pool dig help
    I had the idea of burying my above ground pool so that it would be flush with my existing deck. I though I would need to dig 28" down on the existing deck side and a little more on the opposite side because its an incline. That hill was deceiving and we ended up taking 5 to 6 feet out. I've realized I never should have done this and just intalled the pool on top of the existing ground and cut into the hill as needed. My question is, what happens if I backfill the hole and build? The bury project is a bigger headache then expected and is costing me more money.
    Thanks
    Re: Pool dig help
    When you backfill the hole you need to place the material in lifts and compact it so that the pool won't settle differentially. If you are using a plate compactor you should probably limit the lift thickness to about 8 inches because they don't have very much compaction energy. You only need to worry about the material under the pool bottom. Try to make the compacted zone bigger as it goes down in depth, like if it's 4 ft. thick then make it extend out 4 ft. from the pool sides.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
