Thread: Fix Mineral Springs or Replace w/Pentair Intellichlor?
    ajw22's Avatar
    Jul 2013
    Northern NJ
    100
    I have a Mineral Springs SWG installed in 2005 in my 35,000 inground pool. Looks likes the PCB board has gone bad. It shows -pcb- on the display with all lights on. If I pull all power from it it can be reset and operate again but it has failed twice now so it can't be relied on.
    Pool company can replace PCB board for around $500. They are recommending I replace the Mineral Springs system with a Pentair Intellichlor system for around $1,000. They say they have less problems with the Pentair system. I know in the 8 years I had the Mineral Springs I replaced the cell once, maybe twice, not sure.
    I see where the Pentair Intelliclor has the controls built into the cell and a new cell costs more then the Mineral Springs. If the Pentair will work better and last longer then I would go for it. My rule of thumb is if a repair costs more then 50% of new cost then I go with new. This is right at the edge.
    What do those withe experience here say? Repair the Mineral Springs or replace with the IntelliiChlor?
    Appreciate your advice.
    Allen
    -Allen
    IG 20x50 35,000 gal Cayman Lagoon Hydrazoo plaster w/ spa & waterfall, Pentair Intellichlor SWG, Pentair Mastertemp 400BTU Nat Gas Heater, Pentair FNS Plus 60 DE Filter, Polaris 380 cleaner, Meyco solid winter cover, TF100 Test Kit, Built in 2000 & replastered in 2017
    22,553
    Re: Fix Mineral Springs or Replace w/Pentair Intellichlor?
    How long ago did you replace the cell? If the cell is relatively new I'd repair the system. If it's several years old I'd think about a new system.
    ajw22's Avatar
    Jul 2013
    Northern NJ
    100
    Cell is probably around 3 years old. I can't find the receipt for the exact date. It is a Goldline T-15 cell.
    Allen
    -Allen
    22,553
    At 3 years you're on the edge. I'd say that replacing the system might be a good idea. Here's what I would do. Since you already have a T cell 15 that has some life left, I'd look at another system that uses that cell and go with it. Then, I'd install the new cell just long enough to make sure that it's good, then I'd install the old cell and store the new one for when the old one fails.
