Thread: help with sealing gunite
    Jun 2013
    Plymouth Meeting, PA
    29
    Hello I have a 20 year old pool and spa made of gunite. The spa needs some patching. The patching material is not an exact match of the gunite so I was thinking of staining or something to blend it in. I want to avoid painting it. Does anyone have any suggestions?
    25,000 gallons (in-ground plaster pool+spa)
    Hayward DE Filter, 1.5 hp pump, Polaris 3900 Sport Vacuum, Honeywell Heater
    TF-100 Test Kit, Using TroubleFree Method
    Getting the hang of pool ownership....
    Re: help with sealing gunite
    You can add masonry dye to get the patch material to match the existing plaster. Wet the existing plaster to do the color match. It is a plastered pool, correct?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
