Thread: Nature2 mineral cartridge splitting down the side
    May 2011
    Western New Jersey
    11
    Hi all,
    Each of the past two years I noticed small beads on the pool floor and in the cleaner towards the end of the season. Not recognizing them, it took me a bit to figure out what they were. In each case it was the mineral cartridge, which had split a bit on the side allowing the mineral beads to be pushed into the pool. Because it was the end of the season - I didn't make a big deal of it. Well - year 3 using Nature2 and this time the split has happened mid season. Three in a row takes away the coincidence possibilities. Any ideas of what might be causing this?
    I have read a few of the threads on these mineral cartridges and now understand that they may not be a good idea and I will be thinking about that. For now - I'd like to try to understand why this is happening.
    22,551
    Re: Nature2 mineral cartridge splitting down the side
    Aren't you supposed to change those cartridges twice a year? I'd say that they aren't designed to last very long. Since almost no one here leaves them in we don't have any experience with them.
    What does your filter pressure run?
    Donldson's Avatar
    NW Ohio
    2,905
    Once a year if the pool is closed for the winter, twice a year for year round operation. I owned one, I never will again.
    It sounds like either it isn't sitting correctly in the unit, or by chance are you using an above ground unit on a below ground pool?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2009
    Burlington, ON, Canada
    344
    Really, I would just do away with the mineral cartridge. It's putting metals into your water. I removed mine and haven't looked back.
    Do you have the Duoclear? I did, and I took apart one of the mineral cartridges, removed the bag and reinserted the cartridge shell (the cartridge must be in for the Duoclear to work).
    As to why the bag is splitting...??? Weird.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    May 2011
    Western New Jersey
    11
    It's once a year when you have a pool that is only open part time. I have been changing them yearly. I thought I was indicating as much in my question in that I had mentioned that I was on my third one, each having split at one point during the year. I have removed this one and it doesn't appear to have split down the side. Rather the beads appear to be coming out the top.
    May 2011
    Western New Jersey
    11
    Quote Originally Posted by rcy
    I have the regular version. Just mineral cartridge. I am granting that maybe I need to move away from mineral cartridge. Hoping to understand what is going on. Now three years in a row.
