Thread: Polaris booster pump- quick connect broken off in pump intak
    How do I remove the broken piece of the quick connect from the pump intake.
    Mar 2010
    Spring, TX
    1,082
    Re: Polaris booster pump- quick connect broken off in pump i
    Quote Originally Posted by Jwood7
    I believe they make some type of spray you can spray on the similar to WD40. You could also try a two pair of channel locks if you have them. One on each side.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,550
    Can you post a picture of the pump suction?
    Here's the photo of the broken piece.
