Results 1 to 11 of 11
Thread: Need help with stains in my pool...irrigation or rock??
    Jul 2013
    East Texas
    51
    Ok I am a newbie so be gentle on me...lol,, here is my problems. I have a in ground saltwater pool with a swg..I keep getting a dirty yellow stain. I thought it might be scale so I called a pool guy to come check it out for me. He informed me that I have to much metal in my pool. He asked if I had sealed my rock from around the pool and the water fall lately... Answer was no... He said that the metals from the rock is getting on the kids feet and staining the plaster??? He tried some stain away...which I think is the same as vitamin c??? And got no results.. He wants to do a acid wash...
    Next question.. My irrigation system pulls water out of a pond behind the house. I get some over spray into the pool when the wind kicks up??? Could this be another issue with the stains??
    I hope all this makes sense???
    FC 1.9
    Tc 1.9
    Cc .5
    Ph 7.4
    Ta 110
    CH 360
    CYA 20
    Copper .27
    25,000g In Ground Saltwater pool-plaster--rock water fall with water Jets- Polaris 280 vacum-Hayward ecostar pump- Hayward booster pump-TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Need help with stains in my pool...irrigation or rock??
    Welcome to the forum
    I suggest you do your own testing. Use some cheap vitamin c tabs crushed in a sock and set it on the stain for a few minutes.
    If no joy, test for organic staining - rub/set a trichlor puck on the stain for a few minutes.
    You really need one of the recommended test kits.
    Can you post some pics of the staining?
    You're done SLAMing when:
    Jul 2013
    East Texas
    51
    Let me give that a try.. I tried to post pictures but they are to large...
    Jul 2013
    East Texas
    51
    Updated picture
    Jul 2013
    East Texas
    51
    The top step was acid washed by the pool lady...
    Jul 2013
    East Texas
    51
    What kind of treatment should I do?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Traylork
    I hope you can see the color change. I left it on the step for 15 minutes.
    What did you leave on the step for 15 minutes? Did it lighten the spot where it was?
    Jul 2013
    East Texas
    51
    I left a vitamin C tablet on the step and yes it changed the color.
    Thanks for the response !!
    Butterfly's Avatar
    South Carolina
    10,045
    If the stain is only on the steps, fill the sock with cheap vit C tabs crushed and keep moving it around on the stains.
    Jul 2013
    East Texas
    51
    The stain is on the steps and several other locations.
    Jul 2013
    East Texas
    51
    More pictures
