Thread: Hayward Puresalt Plus System - Not Working
    I have the Hayward PureSwim Plus Salt water system - Just this last wee my pool turned green - after doing some looking around to see what the problem was I discovered that none of the lights are lighting up on my saltwater control panel, although the LCD display screen does turn on - I turned it off and on a few times and still nothing - Can I replace just that control panel I found on online for 80.00 or do I need to replace the entire unit?
    22,553
    Re: Hayward Puresalt Plus System - Not Working
    Take a look at the aquarite thread and see if maybe the current limiter is your problem.
    Just ordered the current limiter from Digi-key.
    Should be here on Wednesday, will let you know if that works - Thanks
