Results 1 to 8 of 8
Thread: Today's Test Results
    So after adding 4# of CYA yesterday and a couple of gallons of 8.25% bleach here are today's results using the Taylor K2006 kit:
    - pH 7.2
    - CYA 30 ppm
    - TA 40 ppm
    - CH 40 ppm
    - FC 4 ppm
    - CC 0 ppm
    Besides adding a lot of baking soda, anything else I need to do?
    Thanks.
    30' used (new to me) AGP (21K gallons), installed 7/13. Hayward PowerFlo LX 1.5 HP Pump, Sta-Rite Cristal Flo 200# Sand Filter.
    Ledyard, CT
    22,549
    Re: Today's Test Results
    That look like about all you need to do. I wouldn't raise the TA too much. You also might raise the cya a little, but in CT, maybe not.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Go swimming.
    Donldson's Avatar
    NW Ohio
    2,893
    Looks good!
    He just added 4 pounds yesterday so he may want to recheck in a week and see if he needs to raise it any more or not.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    So I have another newb question: How long should I run the pump each day, and when should I run it? While the pool is in use, after use, at night?
    Have had the hot tub for four years but this pool stuff is new to me.
    Thanks.
    Ledyard, CT
    Jun 2012
    Howell, NJ
    977
    There is no set amount of time. This article may help: pool-school/pump_run_time
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Thanks John, I appreciate the link.
    Ledyard, CT
    So I added 12# of baking soda yesterday and that brought todays test results:
    - TA 70
    - pH 7.4-7.5 ish.
    - FC was 5
    - CC was 0.
    - CYA still around 30
    These test results were taken about 20 minutes ago after getting up to start night shift at work. I turned on the pump to let it do its job, and immediately a brown plume came out of the pump return into the pool. Lasted for maybe 5-10 seconds and then disappated. Is this normal?
    Ledyard, CT
